I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
912 replies to this topic
#781 imack
imack
  • 2,100 posts
Posted 26 June 2020 - 06:51 PM
That's strange, my ARP's came with two different length rocker studs. Only about 5 threads shorter.
#782 nicklouse
  • 18,562 posts
Posted 26 June 2020 - 07:37 PM
looks like MiniSpares supply both lengths but the Kit i got from MED have them the same length.
#783 imack
imack
  • 2,100 posts
Posted 26 June 2020 - 07:39 PM
My kit came from minispares.
#784 nicklouse
  • 18,562 posts
Posted 27 June 2020 - 08:37 PM
changed out the brake reservoir to MC connections.
works way better.
#785 nicklouse
  • 18,562 posts
Posted 27 June 2020 - 08:47 PM
and it is in and everything connects up.
#786 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 28 June 2020 - 12:18 PM
Wow Nick that's really looking great!
#787 johnR
johnR
  • 2,297 posts
Posted 28 June 2020 - 01:07 PM
looking very purposeful!
#788 nicklouse
  • 18,562 posts
Posted 28 June 2020 - 05:50 PM
right put the rest of the water pipes on. and now to do the wiring.
coil pack will go on the right side bar.
#789 nicklouse
  • 18,562 posts
Posted 29 June 2020 - 05:56 PM
ok you may remember 2 pages back i was grinding away metal from the gearbox and the remote?
nice.
#790 nicklouse
  • 18,562 posts
Posted 30 June 2020 - 05:56 PM
new coil pack mount made. rad mounts adjusted with carriers for the wiring and sender pipes. just a little bit of wiring to sort and fit the rest of the exhaust.
and yes it does still fit under the body.
then it will be time do add fluids.
#791 nicklouse
  • 18,562 posts
Posted 01 July 2020 - 05:07 PM
wiring done, oil pressure acquired brakes and clutch bleed. just needs some fuel adding to it.
tomorrow should be fire-up day.
#792 nicklouse
  • 18,562 posts
Posted 02 July 2020 - 04:06 PM
it is alive
https://youtu.be/OuttTuwkLx0
#793 imack
imack
  • 2,100 posts
Posted 02 July 2020 - 04:10 PM
Nice one
#794 Spider
  • 14,821 posts
Posted 02 July 2020 - 07:20 PM
Nice work Nick. A lot of hours there.
You putting it on the rollers to break it in and have it set up ?
#795 nicklouse
  • 18,562 posts
Posted 02 July 2020 - 07:27 PM
Unfortunately that is not an option. But the spec is basically the same as last time. Need to give it a longer run a# it has had a heat cycle and retorque done. Then it is back onto the trailer till some time it can get set up. But first it needs to be transported back to the UK. Need to get the suspension set up before the rollers.
