That's quite a difference!
I Decided It Was Time To Drag The Race Car Out And Update It.
#766
Posted 29 May 2020 - 09:43 PM
#769
Posted 23 June 2020 - 04:49 PM
#770
Posted 23 June 2020 - 04:53 PM
Very nice. Did your old head repair ok?
did nothing to it it will be fine for a few more seasons.
#771
Posted 23 June 2020 - 05:10 PM
Offer your gearbox up - I had to make some extra relief in mine to accommodate the MED caps & studs at the front.
Edited by GraemeC, 23 June 2020 - 05:16 PM.
#772
Posted 23 June 2020 - 05:13 PM
i am fully aware of this and it will be tomorrows job. but i had heard it was mainly with the center strap studs.
#773
Posted 23 June 2020 - 05:15 PM
Wasn't on mine - see above
#774
Posted 24 June 2020 - 07:11 PM
nor mine.
so what has been going on today. lots of use of a marker pen and a carbide tip.
so innocent and sweet looking
mark grind and repeat until no more rocking.
i think you get the idea.
next was the DSN timing cover. i was aware that some people had been having issues with the cam sprocket position and have been asking about shims for the cam gear which is all not needed..........
so i put the cam assy on and the Crank gear was way proud of the cam gear eeer WTAF
played about with the bearing locating plate new and old. both measured the same and had just barely enough end float. but will do.
so the cam gear is not coming forward time to play about with the crank gear so out with the marker-pen and guess what
well some pics
the new crank has a nice radius on it which stops the crank gear from bottoming out.
gear modified and the gearset line up.
start adding bling.
check timing tomorrow.
also set up the primary gear clearance way tight again with all new parts.
#775
Posted 24 June 2020 - 08:09 PM
Yep - brings back memories. Not fun with a nice freshly built box.
If you have MEDs flywheel bolt, check that too - mine is still sat on the shelf as is the replacement they sent me that ‘had been checked’. Both oversize on the major diameter.
#776
Posted 24 June 2020 - 08:13 PM
Cheers for the heads up but it has been in the crank already. At the machine shop but will double check.
#777
Posted 25 June 2020 - 08:42 AM
Nick, from experience with the DSN covers, put a little sealant around with the rubber O ring. Mine leaked from new and i've replaced the O ring a few times to stop it. Eventually put a little hylomar on the bottom of the seal and its stopped dripping now.
#778
Posted 25 June 2020 - 07:33 PM
steve cheers for that i do tend to use the blue stuff where i thing it is needed even if it may not be required. and in this case it is good for holding the O ring in place.
Cam timing done. had dropped a tad due to the chain wearing but it is still like new. fly wheel fitted etc. first time i have ever fitted a new flywheel into a new crank. not quite as simple as expected. just needed the long bar on it.
then there was the engine steady and how to fix this.
as i now have the dry deck set up the hole is not readily accessible.
so after some thought.
just need a suitable washer over them.
just need to do the valve clearances tomorrow.
#779
Posted 25 June 2020 - 09:48 PM
as many people often ask about how a freshly assemble crank assy should rotate. one handed.
#780
Posted 26 June 2020 - 06:28 PM
why cant people make fasteners as the originals? ARP supply the 4 rocker pedestal studs at all the same length rather than two long and two short. ARP stud compared to the short stud from Minispares.
not much difference but enough to get in the way.
had to swap it out to get the DSN rocker cap on.
all bolted up ready to go in the car
ok still needs some jubilee clips or Norma etc
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
