I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
912 replies to this topic
#751 nicklouse
  • 18,562 posts
Posted 16 May 2020 - 07:05 PM
put the new clutch assy on the scales. 5.2kg
#752 nicklouse
  • 18,562 posts
Posted 17 May 2020 - 09:44 PM
ok something i have been thinking about for some time.
lower engine mount movement
so from an earlier post
ZgvJbFa.jpg?1
engine assembled like this
mounts retained in double shear
with me moving the block as much as possible
Edited by nicklouse, 17 May 2020 - 10:19 PM.
#753 Surf Blue
Surf Blue
  • 35 posts
Posted 18 May 2020 - 09:36 AM
so what is the hold up on the engine.
mmmm
new set on the way and these will be heading back.
What pistons are you using? Quite concerning in the quality control
#754 nicklouse
  • 18,562 posts
Posted 18 May 2020 - 09:56 AM
All the info is in the thread.
#755 Surf Blue
Surf Blue
  • 35 posts
Posted 18 May 2020 - 01:40 PM
So it is, poor for Omega!
#756 nicklouse
  • 18,562 posts
Posted 25 May 2020 - 06:42 PM
So still waiting on stuff getting finished i put out a shout on a local forum if anyone had a head i could borrow.
a friend reply with sure i have a head you can HAVE FOC.
well happy so i drive down to get it and also have a look at his new SPi
now i can get the hoses mocked up and the exhaust position checked.
#757 nicklouse
  • 18,562 posts
Posted 26 May 2020 - 08:08 PM
now the head is on i can see what was happening before with this exhaust.
time to remove some metal.
#758 imack
imack
  • 2,100 posts
Posted 26 May 2020 - 09:07 PM
Have you tried it with the remote attached? Can't remember for certain if the Y piece fouls the remote housing too.
It does on the long 3:1
#759 nicklouse
  • 18,562 posts
Posted 26 May 2020 - 09:21 PM
yep that has now been cut back and those are under tension now so the one on the real box has been adjusted.
#760 nicklouse
  • 18,562 posts
Posted 28 May 2020 - 08:00 PM
so today i have been doing breathers. well i have been looking and scratching my head trying to work out how to do it as the KAD brakes cause routing issues.
well
and yes it does fit.
#761 imack
imack
  • 2,100 posts
Posted 28 May 2020 - 08:07 PM
Where does the 2nd breather pipe come from on the thermostat end of the rocker cover? One obviously comes from the timing cover.
Do you need to add baffles inside the rocker cover?
#762 nicklouse
  • 18,562 posts
Posted 28 May 2020 - 08:13 PM
fuel pump hole. no baffles yet. and not planed.
i am sure there is a reason i have not seen any with the rocker to catch tank taken from the front but have not come across it yet.
#763 GraemeC
GraemeC
  • 7,437 posts
Posted 28 May 2020 - 08:26 PM
Probably no technical reason apart from maybe the 90 degree bend? Probably mainly aesthetics and keeping pipe runs short.
Does the top hose get in the way of getting to no.1 plug?
#764 nicklouse
  • 18,562 posts
Posted 28 May 2020 - 08:28 PM
Top hose will be adjusted to pass between 1 and 2 like before.
#765 nicklouse
  • 18,562 posts
Posted 29 May 2020 - 07:20 PM
someone wants my door hinges so pulled them and for fun put them on the scales.
then i put the new DSN ones on the scale with the supplied nuts
25 user(s) are reading this topic
0 members, 25 guests, 0 anonymous users
