I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
919 replies to this topic
#736 nicklouse
  • 19,058 posts
Posted 23 April 2020 - 08:16 PM
this is getting boring more deliveries today.
the KAD stuff was brakes and clutch related
the Minispares stuff was two things of oil
and some other bits to play with. first was a fail as the threads are different
and this will need bolting to the jig and welding up. and then have some extra bits added.
#737 nicklouse
  • 19,058 posts
Posted 25 April 2020 - 07:48 PM
so two days since that delivery and i still cant find one screw.
but the box is built.and running free.
brake hoses fitted and other lines made.
now to work out the placement of the reservoirs
oh and some brackets made.
#738 nicklouse
  • 19,058 posts
Posted 03 May 2020 - 10:28 PM
right after much discussion it seems that the studs on the clutch side need extending by about 5mm. (or 5mm if the max that can be done or there will be contact).
 so some cutting and grinding and welding will be happening.
not much happened last week as i am waiting stuff.
this did happen which through a spanner in the works abit.
#739 KTS
KTS
  • 2,490 posts
Posted 03 May 2020 - 10:33 PM
What happened there then - fire ?
#740 nicklouse
  • 19,058 posts
Posted 03 May 2020 - 10:38 PM
yep big one.
#741 nicklouse
  • 19,058 posts
Posted 04 May 2020 - 09:04 PM
new studs added
might need a mm or two taking off as i may have not taken enough off.
still waiting on the correct Rose joints
y6NuVEJ.jpg?1
ZgvJbFa.jpg?1
#742 nicklouse
  • 19,058 posts
Posted 05 May 2020 - 08:56 PM
ok so to the rest of the above bracket
front part. extra support added and bush center enlarged to 10mm (somewhere along the line the original hole had been enlarged).
and guess what else i was doing
#743 KTS
KTS
  • 2,490 posts
Posted 05 May 2020 - 09:11 PM
now that is a briliant idea.  fantastic  :D  :D
#744 imack
imack
  • 2,381 posts
Posted 06 May 2020 - 07:12 AM
Yeah like the idea, I normally super glue those to the tip of my finger to install them.
#745 nicklouse
  • 19,058 posts
Posted 09 May 2020 - 06:57 PM
back looking at the brace bars as jamming washers in is not really the way to do it.
the answer was there with the shock mounts.
modified some rocker cover bolts.
spacers  inboard, bolt outboard to finish of the spacing.
#746 nicklouse
  • 19,058 posts
Posted 10 May 2020 - 06:28 PM
still trying to decide how to rout the reservoir hoses.
will keep on thinking for some time
used an old top steady bracket on the lower
still waiting on the machine shop for the engine work.
#747 nicklouse
  • 19,058 posts
Posted 12 May 2020 - 08:50 PM
so what is the hold up on the engine.
mmmm
new set on the way and these will be heading back.
#748 nicklouse
  • 19,058 posts
Posted 13 May 2020 - 08:47 PM
so the reason for the spare block was multi fold.
make a bracket for the engine stand
and then to start working out the new water pump.
#749 nicklouse
  • 19,058 posts
Posted 15 May 2020 - 07:46 PM
change of plan for the water routing.
no water pump this side.
but i will put the pump between the block and head inline with the dry deck hoses.
while i was playing with things i got some scales out.
a pre-verto flywheel  7.2kg
the complete flywheel assy i am replacing about the same weight.
#750 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 15 May 2020 - 07:53 PM
Wow 6 years since you started this thread. Enjoyed the read. Doesnt time fly bye.
