I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
912 replies to this topic
#676 nicklouse
  • 18,562 posts
Posted 01 March 2020 - 09:22 PM
Yes and yes. Hence the question. It moves and then stops.
#677 imack
imack
  • 2,100 posts
Posted 02 March 2020 - 06:26 AM
Does this drilling in the case give access to the detent bore?
#678 nicklouse
  • 18,562 posts
Posted 02 March 2020 - 10:00 AM
Done those.  It’s the one under the big nut on the front.
#679 imack
imack
  • 2,100 posts
Posted 02 March 2020 - 12:19 PM
I thought the big nut was just a blinking plug unless you had a reverse light fitted. Didn't think it had anything to do with reverse detent.
I don't have a Haynes manual to hand to refer to at the moment.
Edited by imack, 02 March 2020 - 05:28 PM.
#680 nicklouse
  • 18,562 posts
Posted 02 March 2020 - 05:15 PM
Well I just have the sealing cap with a spring and a plunger that is operated selector rod. It may have just had the cap put on at some time. But it was a gold/silver seal box when I picked it up.
#681 imack
imack
  • 2,100 posts
Posted 02 March 2020 - 05:19 PM
Ok, just had a look at my spare gearbox, removed nut and there's a spring and plunger.
I wedged a straight pick into the hole in the plunger and it came straight out.
If you can stop it revolving you might be able to run a small tap down it to withdraw it
Edited by imack, 02 March 2020 - 06:02 PM.
#682 imack
imack
  • 2,100 posts
Posted 02 March 2020 - 05:26 PM
Double post
Edited by imack, 02 March 2020 - 05:27 PM.
#683 nicklouse
  • 18,562 posts
Posted 02 March 2020 - 07:15 PM
Nice I can now see what I am trying to get at. Have a pick as well. Will try later.
#684 nicklouse
  • 18,562 posts
Posted 02 March 2020 - 10:37 PM
snap
was not coming out at first every time you started to lift there was a metal clunk and it fell off so ran the pick around the edge and then out it came
#685 imack
imack
  • 2,100 posts
Posted 03 March 2020 - 06:25 AM
snap
I'll have to have a look at the box in my car as I've rebuilt it several times and just don't remember there being a spring and plunger under that nut (it too was also a silver seal 1275gt box I bought in the mid 80's)
How does the plunger interact with the shift shaft? My memory fails me, I don't remember there being a detent.
My spare box has my old engine sitting on it so I can't easily have a look at it.
#686 nicklouse
  • 18,562 posts
Posted 07 March 2020 - 08:50 PM
well the box went off to be washed. and will be going back again as i was not happy with some stuff still on it.
also been drilling and thinking.
the thinking part do i fit a plug or continue the threads through?
next was a thread needed an insert
this tilting table is so useful.
for fun.
the old and new
wMhCHXe.jpg?1
#687 GraemeC
GraemeC
  • 7,437 posts
Posted 07 March 2020 - 11:00 PM
I don’t think I’ve seen an oil pick up pipe boss like that - they usually have the bolts going through from the outside into the threaded flange of the pick up pipe.
#688 nicklouse
  • 18,562 posts
Posted 07 March 2020 - 11:04 PM
You may not we welded it up so we could use a banjo fitting for the remote filter. I am going back to standard as I now have the dog box.
Edited by nicklouse, 07 March 2020 - 11:18 PM.
#689 GraemeC
GraemeC
  • 7,437 posts
Posted 08 March 2020 - 07:32 AM
Personally I’d return it to the standard setup then - two less bolts that could fall into the gearbox if they happened to work loose and you don’t have to drill the pick up out.
My remote filter uses a male thread and a 90 degree fitting. The banjo does look a neat approach.
#690 nicklouse
  • 18,562 posts
Posted 08 March 2020 - 06:55 PM
holes extended and threads cut.
 0nly there as we put them before. will not be defunct.
