Looking good!
I Decided It Was Time To Drag The Race Car Out And Update It.
#286
Posted 30 May 2016 - 08:41 AM
#288
Posted 01 June 2016 - 07:30 PM
#289
Posted 01 June 2016 - 09:10 PM
Looking mega. That paint quality, on a race car!
Thanks but it is just acrilc rattle cans and elbow grease. Oh and the boot lid is just gel coat. As is the front but that needs more work.
#290
Posted 02 June 2016 - 06:39 AM
Looking really nice, just out of interest what sort of angle have you used for the rear diffuser relative to the ground plane?
#291
Posted 02 June 2016 - 07:13 AM
between 10 and 15 %
that was the designed but actual has not been measured yet.
#292
Posted 02 June 2016 - 08:21 AM
Thank you, just to check, you say 10 - 15 percent, so do you mean a 10 - 15% grade / slope or do you mean 10 - 15 degrees?
Edited by SAD_Man, 02 June 2016 - 08:21 AM.
#293
Posted 02 June 2016 - 08:34 AM
degrees. flat surface. basically the angle made from the heel board to rear panel. actual angle relative to the ground will depend on how the car sits.
#294
Posted 02 June 2016 - 09:08 AM
OK cheers, yeah I get about 12.5 degrees (relative to the floorpan plane) from the base of the heelboard to the rear panel / rear valance seam. As you say plus whatever rake you run.
I think you mentioned before you work on underbody stuff? Have you any experience of varying rear diffuser angle and the maximum usable angle from other work?
Edited by SAD_Man, 02 June 2016 - 09:21 AM.
#295
Posted 02 June 2016 - 09:32 AM
not actually something that came into the work envelope (not really relevant on serial production cars) BUT having spoken to a few people (I suggest you also ask more people) 10-12 was given by one. further reading suggested that was about right. BUT again this was all stated to ground plane so from that I can only guess they are running the floors parallel to the ground.
Points I will make are these air will get under your car. reduce this as much as you can. then control any air that is under the car to go where you want it to go.
All short wheel base cars with a rounded rear suffer from brake induced lift.
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects →
Mini Saloons →
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects →
Mini Saloons →
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
