I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
912 replies to this topic
#211 Tupers
Tupers
  • 4,142 posts
Posted 14 October 2015 - 07:26 PM
I like the grommet for the battery cable. It's certainly a much tidier than the traditional ones. The new air dam looks good as well, are you going to connect vents up to some ducting for the brakes?
Every time you update this thread I feel a strong urge to buy another shell and build a hillclimb car.
#212 nicklouse
  • 18,562 posts
Posted 14 October 2015 - 07:34 PM
I did not really want the vents. But was not an option. They also intersect with the metal work of the floor. They will be cut down and blanked.
Well that is the plan at the moment.
#213 nicklouse
  • 18,562 posts
Posted 15 October 2015 - 06:27 PM
More bits
1202026E-8B50-4CB2-A2AC-F5E6C118EECB_zps
B58E7074-6559-4847-8E4E-7EFA8C03353F_zps
3BCDB588-1EA4-4314-93FB-DEE100A3DC89_zps
Cheers Mondo Motorsport
#214 Tupers
Tupers
  • 4,142 posts
Posted 15 October 2015 - 10:34 PM
Very nice. I've got a pair on my clubman estate although it's not gone anywhere yet.
#215 nicklouse
  • 18,562 posts
Posted 17 October 2015 - 04:58 PM
Just been playing with mock ups today.
C9E57D76-2BF5-4815-81E1-A7A6A1E68D72_zps
Of to see another car tomorrow as it is often easier to get your head around new rules and regs by seeing something that complies.
#216 nicklouse
  • 18,562 posts
Posted 17 October 2015 - 11:40 PM
Did they screw right down on the hub or was there a gap?
#217 nicklouse
  • 18,562 posts
Posted 24 October 2015 - 03:59 PM
Belt bar in.
EB08F288-8002-4714-8868-43F59A2E1A0D_zps
Ball joint spacers tomorrow.
#218 nicklouse
  • 18,562 posts
Posted 25 October 2015 - 06:30 PM
Finally got around to the ball joint spacers. Interesting fitting.
EAE0984E-C102-4F41-A254-7B1DB327CE50_zps
Decided to change the position of the ARB bar.
Started with the electrics.
Might flip the p clips on the front bit,
2962DD21-B992-4316-8A2E-BC0494E20E6D_zps
This is for the starter as the relay will be in the car.
#219 nicklouse
  • 18,562 posts
Posted 08 November 2015 - 07:24 PM
Sorted out some bits from the front panel.
92651026-B17A-4CD4-A7D5-8654766113CB_zps
Drilled out the welds
0D207383-5322-4085-8AC9-E82073F09B27_zps
4AA63405-813C-433D-BFED-3E65D2A1472C_zps
Welded in a suitable washer to half a pear drop.
F3C5D5FF-8D79-4014-AB07-081A13E20069_zps
CB4B04C8-9622-47C3-A122-6BE19972FDF8_zps
Read to bond to the new front end.
Oh did I not mention that. New front end and bonnet and boot lid are ordered.
#220 James_eaton_thewholething
  • 1,063 posts
Posted 09 November 2015 - 04:01 PM
What are you using to bond the front on ?
#221 nicklouse
  • 18,562 posts
Posted 09 November 2015 - 04:06 PM
note sure yet. but i guess some sikaflex 221 or something similar. need to check the specs.will have a few fastners as well.
#222 James_eaton_thewholething
  • 1,063 posts
Posted 09 November 2015 - 06:13 PM
Fair enough I need to get some sikaflex when I get paid so I can bond some brackets on for mounting arches and bumpers
#223 nicklouse
  • 18,562 posts
Posted 09 November 2015 - 09:20 PM
Just had some pictures sent from ABS.
D878F2CE-0D62-4D6E-A505-4B23A3CEFB48_zps
92BA9030-DA94-4692-B718-2E40E3D571E0_zps
New two piece front. Should polish up ok.
Shane I don't get to see it for about 5 weeks.
#224 Baldspeed Racing
Baldspeed Racing
  • 1,193 posts
Posted 10 November 2015 - 07:49 AM
nice little touch with the front end panel sections never thought of doing that before
#225 nicklouse
  • 18,562 posts
Posted 10 November 2015 - 08:31 AM
as it is a two piece so the need to remove it all the time is less than with the old one piece and also wanting to get it in the right position. not using a rubber mount just one side with a washer welded in to reduce the hole size. slides onto a 12mm rod. the front brace and M12 nut and the half a pear drop give the right thickness to space of from the front subframe give or take a mm or 2. thinking of putting a couple of rivnuts into the hole in the brackets to help with the bonding and security.
to be honest i am suprised that the panel people dont do them as an off the shelf item.
