I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
912 replies to this topic
#136 nicklouse
  • 18,562 posts
Posted 15 May 2015 - 06:11 PM
Long way off. Needs full plumbing and wiring.
Gear lhouding attached and mounted. Silghtly odd in that it did not want to fit on the holes I made last time. Might have mounted it in a different hole on the bracket.
E832C706-7FA3-45E9-B110-9828E7B3B049_zps
#137 nicklouse
  • 18,562 posts
Posted 15 May 2015 - 06:20 PM
Right front splitter and air dam.
First things first fine a suitable material to use. 3mm hard board. Went for some with a white surface as it is easier to see lines on.
1725FD5A-8CAF-4E17-BD25-4A931F773250_zps
B8364653-CF85-4CA3-92F2-E8B1481655CA_zps
8F75ABA5-C660-4389-B31D-66AC5EBC29E9_zps
8D9533AC-EE7E-4829-9304-5BE6450CD467_zps
Corners will be rounded off.
Air damn will finish it of like this, but this is the old one.
85D707AE-5EAD-40A2-ABCA-2401B6EC4D41_zps
#138 nicklouse
  • 18,562 posts
Posted 16 May 2015 - 06:19 PM
New frame made still needs some curves and cross pieces but lack of metal and an empty gas bottle have put a stop to that for now.
BDCB1D0F-AE09-4B36-91AF-7F8F5E4ACFCA_zps
Can you guess what is will be?
A2931488-B557-4EFD-AD48-54F79614B496_zps
#139 Tupers
Tupers
  • 4,142 posts
Posted 16 May 2015 - 06:30 PM
Looks like a superbly designed diffuser if you ask me.
Or maybe it's a blue print for a 3 column bridge?
#140 nicklouse
  • 18,562 posts
Posted 16 May 2015 - 10:10 PM
I have just realised dome of what I marked as waste was not.
So bridge maybe.
Would you belive my current work is designing underbody aero panel. Yes real paid work. So much easier in CAD. Than CAD.
#141 nicklouse
  • 18,562 posts
Posted 19 May 2015 - 07:10 PM
Just had a play moving the ARB to above the tie bars.
ABB4CC7A-5AC4-4E88-A1AB-B35D0A6B55C4_zps
Nope too close to the CV boots. But has me thinking about mounting it in another place.
#142 nicklouse
  • 18,562 posts
Posted 23 May 2015 - 07:37 PM
Well today was a day playing with wood.
59BDD306-4120-4ED2-B5BB-520865B04851_zps
B10E0288-E643-4379-B360-E14C24736E9C_zps
0AA52C9B-F744-4E7A-B514-F66A29F551F0_zps
#143 Alex_B
Alex_B
  • 4,573 posts
Posted 23 May 2015 - 08:15 PM
Floors looking good! Are you planning to calculate the aero benefits of it or just by the seat of your pants?
#144 nicklouse
  • 18,562 posts
Posted 23 May 2015 - 08:52 PM
Claculate? Not got the wind tunnel or the CAD model to run in the software.
But just using some basic rules and known behaviour. I should end up with a better result than before.
The front is kinda the hardest as it does need to be easy to remove but yet still work with the front air dam.
The rear and side will be simpler just requiring bent sheet alloy. The cost there is the bending and the welding after the cardboard models.
#145 Alex_B
Alex_B
  • 4,573 posts
Posted 23 May 2015 - 08:56 PM
Gotta model it and run it through CFD, half the fun of it!  ;D
#146 nicklouse
  • 18,562 posts
Posted 23 May 2015 - 09:27 PM
Not got the time or the inclination. Do enough of that during work hours.
#147 nicklouse
  • 18,562 posts
Posted 24 May 2015 - 05:12 PM
Here it is not hiding under the engine.
8CFDF934-CB1A-4033-BBCC-06BCA5A78E0A_zps
#148 Tupers
Tupers
  • 4,142 posts
Posted 24 May 2015 - 05:27 PM
Very snazzy indeed.
I've always thought it'd be interesting to work up an aero kit and do back to back test with and without it at a practise day.
#149 nicklouse
  • 18,562 posts
Posted 25 May 2015 - 04:56 PM
Connected up the driveshafts today. I had forgotten what a untc the short one is. Had to drop the hub off.
Hardyspicers by the way.
3C12EC81-55D8-4A8C-AD68-65C37FBD2A2E_zps
Added a few more bits back on as I will soon be doing the plumbing and wiring....
#150 Midas Mk1
Midas Mk1
  • 5,773 posts
  • Local Club: S.U.N.M.C
Posted 25 May 2015 - 06:54 PM
Looking good! Was wondering what alternator setup you using with the front mounted rad?
