Brand New Head Gasket... Coolant Leaking!
40 replies to this topic
#1 RooBoonix
RooBoonix
  • 1,224 posts
Posted 21 September 2014 - 07:28 PM
Hello everyone,
After spending the most of today getting my engine back together with a new head gasket, setting valve clearances and all the other malarky... I found a bit of a problem!
I used the SPi head gasket kit from Minispares which comes with the black headgasket (I believe is the BK450?) and as I was filling the water system, the water started leaking all out the front and side of the block (front and drivers side for sure, not sure about the back)! I didn't even get to start it!
Yes, I did torque it down following the Haynes manual first to 34nm in a spiral, then to 68nm in a spiral. The head was freshly skimmed and the block face I had gone over with a scraper to make sure there was no left over residue that could make the gasket not seal properly.
I have a friend coming round tomorrow who is a VERY experienced mechanic to look and see if I done anything wrong. Is this a common problem here? Anything I should look out for when I take the head off again tomorrow?
Thanks,
Cam.
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 21 September 2014 - 07:33 PM
Have you done a heat cycle then re-torqued the head yet?
#3 RooBoonix
RooBoonix
  • 1,224 posts
Posted 21 September 2014 - 07:38 PM
Not yet. I have read that some head gaskets require a heat cycle before the coolant filling, should I tighten the head nuts down (I loosened them to make it easier to get it off tomorrow), fill the oil and do a heat cycle? If it's that simple then.. great :D
Thanks for your reply,
Cam.
#4 MrIan
MrIan
  • 125 posts
Posted 21 September 2014 - 07:55 PM
Surely if the water is leaking out as you're filling it there's something seriously wrong with the seal. Does anyone do a heat cycle with no water in the head ? Because that's what you'll have. Sounds like a recipe for damage to me.
#5 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 21 September 2014 - 07:57 PM
May and silly but the gasket is on the right way around?
#6 RooBoonix
RooBoonix
  • 1,224 posts
Posted 21 September 2014 - 08:01 PM
Yes I believe the gasket is on the right way round.
Cam.
#7 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 21 September 2014 - 08:17 PM
I have never needed to slacken and retighten the head bolts after running the engine and not had a problem,my guess is the gasket is the wrong way round, they should be marked top and front.
#8 RooBoonix
RooBoonix
  • 1,224 posts
Posted 21 September 2014 - 08:24 PM
I looked and it had no marks on it saying orientation. My only guide was the blanked hole in the top left corner of the block. Where on the top right where was a water/oil way (can't remember which) and the other side was just black so I put the side with the copper sealing ring on the water/oil way and on the other side was just a black rubbery ring (only one on the whole gasket).
Cam.
#9 RooBoonix
RooBoonix
  • 1,224 posts
Posted 21 September 2014 - 10:35 PM
Here is a picture of the leaking...
[URL=http://s1181.photobucket.com/user/RooBoonix/media/Mobile%20Uploads/20140921_185601_zps06898740.jpg.html]
Opinions on what to do?
Cam.
#10 nicklouse
  • 18,581 posts
Posted 21 September 2014 - 10:54 PM
To me it just looks like you have not fitted it correctly.
Head off clear water out of cylinders, oil etc and try again.
Edited by nicklouse, 21 September 2014 - 10:54 PM.
#11 RooBoonix
RooBoonix
  • 1,224 posts
Posted 21 September 2014 - 11:14 PM
Luckily I hadn't filled the oil yet so I'll take the sump plug out and drain any water that got in there and I'll try again tomorrow with the help of my friend.
Thanks guys i'll report back my results!
Cam.
#12 grumpy dad
grumpy dad
  • 305 posts
Posted 21 September 2014 - 11:35 PM
Hi
looks to me as though you have no washers
under the head nuts
so you have bottomed out the nuts
on the thread on the studs
#13 RooBoonix
RooBoonix
  • 1,224 posts
Posted 22 September 2014 - 06:44 AM
The head nuts are the flanged type and there were no washers when I took them off.
http://www.minispare...45.aspx|Back to
These are the ones, and I'm 99% sure the threads aren't bottomed out. I'll take a look for sure later though. I've got all the old bits I took off the engine in the shed so I'll look through and see if I can find any.
Cheers,
Cam.
Edited by RooBoonix, 22 September 2014 - 06:48 AM.
#14 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 22 September 2014 - 07:57 AM
Hi
under the head nuts
The later nuts are flanged and dont require washers unlike the eariler nuts.
I'd be removing it and checking/double checking the gasket is the correct way before anything further.
#15 RooBoonix
RooBoonix
  • 1,224 posts
Posted 22 September 2014 - 08:53 AM
Hi
under the head nuts
I thought this was the case. I'll post back later with my findings
