My Damaged 1990 Brg Mini Mayfair Project
96 replies to this topic
#46 zeemax89
zeemax89
  • 129 posts
Posted 06 July 2015 - 10:43 AM
This stuff will ensure the floor rivnuts don't work loose and start spinning. (the loctite not the coffee)   I went for steel ones in the end to ovoid differing metals which start corroding as soon as the make contact
Attached File  LOCTITE 290.jpg   26.55K   12 downloads
#47 zeemax89
zeemax89
  • 129 posts
Posted 09 July 2015 - 09:06 AM
I used an old tin of panel wipe for cleaning the original underseal off.  Wow it worked a real treat.
Before:
Attached File  20150706_203137.jpg   58.22K   19 downloads
After:
Attached File  20150708_202227.jpg   50.28K   21 downloads
I loctited the rivnuts in.  In the end I went for M5 size.  my only concern is they stand quite proud inside the floor channels within the cabin.  I am considering drilling them out and mounting them from the inside, then fix the p-clips upside down,
Attached File  20150708_190330.jpg   39.04K   19 downloads
Slight dilemma   I replaced some of the lower bulkhead panel as the tin worm had got to it.  But i think there was either two holes or a captive nut plate fixed to it for the throttle pedal to screw to.  Can anyone confirm this or even have a good picture of the location.  the last thing I want is a wonky accelerator pedal..
PLease help if you can, i want to have the floor ready to sea up this weekend and start on the A-panels / wings
Edited by zeemax89, 09 July 2015 - 09:15 AM.
#48 zeemax89
zeemax89
  • 129 posts
Posted 10 July 2015 - 08:57 AM
Got a cheeky hours work in last night.  Loving this welder in comparison to mine,  Much easier and constant with regards to settings.
Rear valance on.
Attached File  rear valance.jpg   27.5K   18 downloads
Attached File  OS rear valance.jpg   29.42K   22 downloads
Attached File  20150709_212629.jpg   26.63K   13 downloads
I am going to see about having a half day today.  I need to go and sort this throttle pedal position.  Looks like i will need to make a guess.  thanks for all the help TMF!
Then put her on her belly, tidy a few areas at the front end up, then see about wings A-panels and front panel......
Looking forward to it
#49 zeemax89
zeemax89
  • 129 posts
Posted 16 July 2015 - 11:40 AM
Had a day off work yesterday so I tried to get some work on the mini done.  Mainly getting the front end in order.
The first problem was the inner wing to A-panel fold was protruding to far and would have not lined up well.  So the first job was to edit this as follows.
Attached File  20150715_180207.jpg   23.9K   17 downloadsAttached File  20150715_181455.jpg   21.7K   18 downloadsAttached File  20150715_183443.jpg   22.73K   12 downloadsAttached File  20150715_184707.jpg   23.71K   11 downloads
Attached File  20150715_190121.jpg   23.2K   17 downloads
Quite happy with the mocked up gap there so I could not resist trying a few more panels.  The following pictures required some fettling with the front panel lower corners.  Having said that this is clamped on with only 3 mole grips so It should all pull together nicely.  I hope  lol
Attached File  20150715_190548.jpg   50.93K   20 downloadsAttached File  20150715_190603.jpg   56.77K   7 downloads  I decided to reuse the old front panel as it is very good condition with no rust to speak of, and my budget is getting low..
Next I had to whip the panels back off and offer up the inner wings.  I did have a problem here, the NS inner seem to long at the lower front edge so would not meet the front panel properly.  Here is a picture of the OS, compared to the NS
This one is not to bad, but will get a bit of tweaking before is welded
Attached File  20150715_231807.jpg   25.64K   13 downloads
This is the one that needs most of the work  Attached File  20150715_231741.jpg   24.38K   11 downloads
So that is tonight job, Then I will refit the panels, check fitment.  Then I think I will repair the rear, top edges that the wings spot weld to, as an old repair is suffering at present
Edited by zeemax89, 16 July 2015 - 11:48 AM.
#50 johnR
johnR
  • 2,297 posts
Posted 16 July 2015 - 12:14 PM
Have you sorted your throttle pedal position? You should be able to gauge it form the throttle cable hole above.
There are captive nuts - I can take a picture of mine if still needed?
JohnR
#51 zeemax89
zeemax89
  • 129 posts
Posted 16 July 2015 - 12:16 PM
JohnR
Hi John,
I did. I looked at the old Crosmember remains and used the throttle cable guide hole also with a picture and got it all lined up nicely I think.
#52 zeemax89
zeemax89
  • 129 posts
Posted 20 July 2015 - 10:30 AM
I spent a lot of time on Saturday fitting panels, removing panels, adjusting panels and repeating until I got to a point I was quite happy before fitting the inner wing repair panel in its final location.  The next step is to repair the rear part that meets the scuttle panel so it all lines up nicely.
Attached File  NS inner wing on.jpg   27.85K   17 downloads
#53 zeemax89
zeemax89
  • 129 posts
Posted 30 July 2015 - 10:45 PM
Attached File  20150726_185352.jpg   26.75K   23 downloadsAttached File  20150730_201003.jpg   22.64K   14 downloadsAttached File  20150730_202123.jpg   28.14K   18 downloadsAttached File  20150730_202317.jpg   22.18K   15 downloads
#54 zeemax89
zeemax89
  • 129 posts
Posted 26 August 2015 - 10:02 AM
Must find motivation to get front on!  Anyone in Reading area with previous experience?  lol
#55 zeemax89
zeemax89
  • 129 posts
Posted 01 October 2015 - 09:12 PM
Can anyone provide some good pics or dimensions for the fuel tank securing bracket thats welded to the rear boot floor?
I hope to have the front end done this weekend. The its just the tank bracket and a rear companion bin to do before paint prep...
#56 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2015 - 09:51 AM
yes, hang on..
#57 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2015 - 10:02 AM
I can't find it at the moment, ill check again later
Ben
#58 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2015 - 07:39 PM
aha, check on this thread i started
http://www.theminifo...ap#entry3304955
#59 zeemax89
zeemax89
  • 129 posts
Posted 02 October 2015 - 07:46 PM
I would also love to spray the car in 2K, homentwever I don't have the required breathing equipment.   Looks like celly it is!  :-(
#60 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2015 - 09:47 PM
It's not just the breathing equipment that you need mate.
You also need proper extraction and ventilation
