My Damaged 1990 Brg Mini Mayfair Project
96 replies to this topic
#16 zeemax89
zeemax89
  • 129 posts
Posted 20 November 2014 - 09:33 AM
OS outer sill on.  The body has now been flipped over.  Tonight I will try to get the brace bars accross the doorway and one to the main floor box section.
Attached File  Image00001.jpg   34.21K   52 downloads
Attached File  Image00002.jpg   112.61K   37 downloads
#17 Steve G
Steve G
  • 130 posts
Posted 20 November 2014 - 10:16 AM
It didn't look too bad in the first photos ! It looks like you are getting on with sorting it out quickly though.
#18 zeemax89
zeemax89
  • 129 posts
Posted 20 November 2014 - 11:24 AM
yea I know it looked ok, but the rear subframe pretty much fell out from the heel panel mounts.  Tonight I want to get the Nearside floor cut out and cleaned u.  I just hope I get the new floor / sill section delivered tomorrow.
I am trying to get on with it quite quickly as I hope to get a Mk1 soon and this is kind of in its space.
Still a list to do:
boot repair left, right and rear
Rear valance
closing panels
Front engine bay crossmember R/h side  (Brake fluid corrosion)
Shock mounts
Inner wings
A panels
Wings
Paint
reassemble
Wow, reads like a lot now I have actually written it all down  lol
#19 zeemax89
zeemax89
  • 129 posts
Posted 21 November 2014 - 11:25 AM
Reasons not to use cover sills...
I know most of you know this already, but if just 1 person reads this and thinks "no, i won't buy, and fit those nasty sills" then this post has helped
#20 zeemax89
zeemax89
  • 129 posts
Posted 27 November 2014 - 11:04 AM
Oh I wish people would let you know when things are out of stock before they put your order on hold awaiting new stock.
 I really could have done with the other panel to be getting on with.  Oh well, hope it arrives today.
Had to make do with making up a repair for the bottom of the rear bin and the wheel arch repair / closing panel
Corroded bottom edge
Attached File  20141122_1205391.jpg   44.63K   17 downloads
Mocked up repair panel
Attached File  20141122_1208551.jpg   43.24K   24 downloads
Scribed down replacement panel
Attached File  20141122_1210281.jpg   37.82K   11 downloads
Corrosion cut away to scribe line, with panel clamped in place awaiting paint removal for welding
Attached File  20141122_1224331.jpg   42.32K   23 downloads
#21 zeemax89
zeemax89
  • 129 posts
Posted 27 November 2014 - 11:15 AM
Grr  well the parts I don't need yet have just arrived.  Literally when I hit post on my last post the courier walked in.  My only problem with them is they are all magnum panels.  to be frank I have not many complimentary things said about them.  Door Steps, front fitch / inner wing repair.
The boot side repair panel looks to me like it is just a cover panel.  this is not what I had in mind..........  Maybe should have used M-Machine.  have liked all the stuff I have received from those Guys an Gals
Edited by zeemax89, 27 November 2014 - 11:17 AM.
#22 zeemax89
zeemax89
  • 129 posts
Posted 05 January 2015 - 12:37 PM
Attached File  Image00002.jpg   125.13K   42 downloads
Attached File  Image00003.jpg   107.74K   23 downloads
Attached File  Image00001.jpg   120.3K   20 downloads
#23 zeemax89
zeemax89
  • 129 posts
Posted 17 February 2015 - 04:34 PM
Boot floor repairs are underway,
firstly I made up a brace using the subframe dimensions as originally made 38.5" from rear left - right mount and bolted it it place.
Then it was a case of remove the multiple bodge plates that were the boot floor, including the crumpled rear section that sits under the near side rear light.  Most of the time was taken in removing the layers and layers of patchwork that had been undertaken in the past 25 years
Edited by zeemax89, 17 February 2015 - 04:37 PM.
#24 zeemax89
zeemax89
  • 129 posts
Posted 24 March 2015 - 10:30 AM
This is the next problem to tackle.  The subframe top mount holes are ovaled.  Is this common or due to the impact on the nearside?
I kind of doubt its impact related as the deformations seem to be in the wrong direction. maybe from running around with worn or lose tower mounts / bolts
Attached File  20150321_145217.jpg   53.18K   39 downloads
Removed that mess to find more mess under it
Attached File  20150323_163339.jpg   47.07K   34 downloads
I then started fabricating repair patches that were butt welded in situ after all the rust was removed
Attached File  20150323_163417.jpg   27.72K   20 downloads
Once the repairs were in place I checked the fitment of the crossmember repair and the distance from the other side.  30.25" edge to edge
Attached File  20150321_175344.jpg   41.47K   22 downloads
I did get the crossmember welded in last night.  I am very happy with the welds.  My welder has problems with the thinner material at minimum current, but once you are welding materials above 1 mm in thickness it runs beautifully. Will take some snaps tonight.
Anyone have any images of the spreader plate that needs to be welded to the end of the member before the inner wing repair
#25 zeemax89
zeemax89
  • 129 posts
Posted 26 March 2015 - 11:38 AM
I think I am loving this colour scheme for mine.
Attached File  Grey Mk1.jpg   52.55K   26 downloads
#26 mk1leg
mk1leg
  • 9,343 posts
Posted 27 March 2015 - 08:54 PM
Nice work..... :highfive:
#27 zeemax89
zeemax89
  • 129 posts
Posted 29 April 2015 - 02:28 PM
I was waiting all week for my new mount straps to arrive for the front subframe, then I could get on with fixing the toe panel in.  So instead I got on with the front bulkhead crossmember ends.  All went quite well and as I thought lots of rust was in hiding
Attached File  20150420_200457.jpg   44.09K   17 downloads
Attached File  20150425_132615.jpg   27.94K   13 downloads
Attached File  20150425_132658.jpg   24.97K   13 downloads
Attached File  20150425_133249.jpg   24.78K   11 downloads
Attached File  20150425_142346.jpg   14.74K   13 downloads
Now just to see how it will fit......
Attached File  20150425_142602.jpg   43.65K   28 downloads
I am assuming it would make sense to get the subframe in, toe panel in and then the front panel on before I weld the inner wing repair in as it should help with the alignments.
Does that make sense to the experts?
#28 zeemax89
zeemax89
  • 129 posts
Posted 29 May 2015 - 02:24 PM
Here's the updated mini work.  I still need to finish of the drivers inner wing, OS boot floor / battery box.  then I think i can get A-panels, wings front panel on and ready for paint.
I hope to be there in a month
http://www.mini-doct...o.uk/body-work/
Edited by zeemax89, 29 May 2015 - 02:31 PM.
#29 johnR
johnR
  • 2,297 posts
Posted 29 May 2015 - 03:42 PM
Agreed that grey colour scheme looks lovely - very understated - was my second choice for my car after the red I went for
Keep up the good work.
It's certainly sensible to use the front subframe as a reference for the front end as you've done.
JohnR
#30 zeemax89
zeemax89
  • 129 posts
Posted 29 May 2015 - 05:11 PM
Does anyone have experience fitting external door hinges.  i just love the look of retro mini's
Edited by zeemax89, 29 May 2015 - 06:59 PM.
