Gearbox Noise Whining (Video!)
6 replies to this topic
#1 Javiagus
Javiagus
  • 55 posts
Posted 17 September 2014 - 03:33 PM
Hi guys!
I have a whining noise in my gearbox and I don't know if it's normal or not. Does anybody have the same noise? I attached a video of this (sorry about the quality). In 1, 2 and 3 it sounds like in the video but in 4 it disappears. Somebody knows if I use some "oil treatment" or something like this it could help? I always use Castrol 20w50
Best regards!
Javier
#2 Ethel
  • 25,919 posts
Posted 17 September 2014 - 04:31 PM
what video's that then???
In fourth the input and output shafts are just linked, all the others use the laygear. It's probably related, but it doesn't narrow it down much.
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 17 September 2014 - 05:47 PM
The whine will be fine as its disappeared in 4th, called gear whine :)
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 September 2014 - 06:06 PM
The whine disappears in 4th because the torque load is taken off the laygear...
Unless its a straight cut gearset then it's your layshaft and bearings which are worn and starting to break up.
#5 Javiagus
Javiagus
  • 55 posts
Posted 17 September 2014 - 06:52 PM
Sorry guys, here are the videos!
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 September 2014 - 07:09 PM
What you have there is a perfectly normal mini gearbox sound...
When you get a "WHINE" you will know about it...
#7 Javiagus
Javiagus
  • 55 posts
Posted 17 September 2014 - 07:35 PM
Thank you very much GearboxGuru! i though i had a problem with this...
