Oversills, What They Are And Why You Want To Avoid Them
195 replies to this topic
#91 Stu.
Stu.
  • 912 posts
Posted 20 November 2014 - 08:16 PM
Lift the carpets where the floor abuts the sill / door frame on each side. You'll soon find out whether there is any advanced corrosion in the sill from the condition of the floor.
Below is a photo of an oversill peeled back to see whats left of the original sill below. The shell is inverted.
This photo shows an inner sill repair panel planted over the existing inner sill. The car has existing oversills on. You can see the damage to the base of the inner sill repair already coming through. This lot will be cut out when I start on the shell. Planting repair panels over existing corroded panels just costs more and causes more damage in the long run !
Edited by Stu., 20 November 2014 - 08:20 PM.
#92 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,847 posts
Posted 29 November 2014 - 05:17 PM
Just flipped my shell, this is what an oversill did to the other side....
1526903_1514027408857181_813643897146960
#93 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 30 November 2014 - 07:37 PM
tasty
#94 Dirk2514
Dirk2514
  • 61 posts
Posted 04 December 2014 - 05:12 PM
Read this last night, so just been out to check my recently bought mini. Damn!!!  does this mean im gonna have a shed load of rust & problems ahead?. The car seems quite solid, what i can see, should i change the oversills to proper ones.
#95 jccc78
jccc78
  • 113 posts
Posted 04 December 2014 - 05:35 PM
yes I would change them asap     a old trick was to fit oversills  to cover up and save time doing a proper job   I seen loads like it
if your buying a mini from a garage etc and they are saying its been restored etc check for oversills if there fitted walk away  there will be rust under the sills
#96 Dirk2514
Dirk2514
  • 61 posts
Posted 05 December 2014 - 03:21 AM
erhhh im scared!!!  i dont want to find a mess underneath. im tempted to use the " ignorance is bliss" thingy so i can use it for a while first. How much would it cost to have a profesional put right a job such as you found in your pictures??
#97 jccc78
jccc78
  • 113 posts
Posted 05 December 2014 - 08:28 AM
Longer you leave it the worst the tin worm will get costing more to fix. I would sort its soon as possible
#98 samg2007
samg2007
  • 499 posts
Posted 15 December 2014 - 12:07 PM
So, like many before me, I had nice clean looking oversills on my mini and I decided to chop them off.
I understand for the most part how the panels are meant to go back on, but I'm a little confused about the metal in the companion boxes in the rear. I seem to have a gap between the quarter panel and the inner sill.
Is this normal?
Having an oversill would have kept the water out, but putting the normal sill on will have air holes that let water and crud into the car. I've made a rubbish picture below. The blue line in the new sill, black is the inner sill and the arrow is the gap im worried about.
I hope that makes sense, any guidance would be appreciated.
Screen%20Shot%202014-12-15%20at%2012.03.
#99 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,021 posts
  • Name: Neil
Posted 15 December 2014 - 01:08 PM
Yes there is supposed to be a gap there as to why the design is like that I can guess but that would be it.
The biggest problem with Oversills other than the water / moisture trap is they are not the correct section, in other words they do not form the correct cross section for strength which the standard short sills have been designed for. So that makes them inherently weaker.
Now yes the fluted open short sills can get muck and moisture in them but at the same time it can get out as well. Any moisture that gets into a Oversills will sit at the bottom which will lead to rust.
Yes you can pump Waxoyl or whatever into them and if done correctly they will last but for all those cars out there with Oversills slapped on and no protection added internally are just a ticking time bomb.
Now with you as a potential buyer who happens to know his way around a mini would you pay £3k for a "restored" mini??? I know I would not if it came with Oversills on. That to me smacks of something not right, whether it's a bodge job, laziness or whatever.
If you want the car to be correct and if you want to sell it on in the future then do the job correctly, fit the correct short sill.
#100 samg2007
samg2007
  • 499 posts
Posted 15 December 2014 - 01:17 PM
Thanks sonikk.
#101 benm
benm
  • 111 posts
Posted 03 January 2015 - 09:20 AM
finally finished the repair to my oversill damaged mini!
took him for a drive last night first time in 3 months :D Was fantastic... untill I broke an engine steady :mmkay:
quite pleased for my first ever sill replacment :)
#102 Carlos W
Carlos W
  • 10,114 posts
Posted 03 January 2015 - 10:40 AM
It'll be far better in the long run
#103 ac427
ac427
  • 670 posts
Posted 12 April 2015 - 11:05 AM
Buggewr, i might have had those on my old Mini.  I remember years ago the bloke saying oversills would be fine.  They even welded the external hinge panel over the old one.  Can't anyone do a proper job these days.
#104 Ethel
  • 25,854 posts
Posted 24 April 2015 - 12:39 AM
Look under the plastic seam moulding. There should be just two edges - the sill and the door step. If the sill's been clagged over the old one there'll be a third, likely crusty, one in the middle.
Is this normal?
Is that as seen in the companion bin? That's how it should be http://www.theminifo...mini-adventure/
#105 eean
eean
  • 161 posts
Posted 04 May 2015 - 05:36 PM
Just took my oversill off on the mini, yep its a bodge job, where's the best place to get replacement orig/heritage proper sills from? Moss do a pair for 74 quid which seems reasonable, only my heritage everything panelwise for my mg midget were a t@#t to fit!!
Can anyone recommend a good pair please? Cheers Iain
