Oversills, What They Are And Why You Want To Avoid Them
195 replies to this topic
#16 brownspeed
brownspeed
  • 451 posts
Posted 20 September 2014 - 08:26 AM
also worth bearing in mind that while it looks nice and sturdy on the outside- the original sill will still continue to rot away- continuing its cancer onto any surrounding sections..........
#17 Corey96Williams
Corey96Williams
  • 316 posts
Posted 20 September 2014 - 09:05 PM
If you were buying a Mini, how would you go about finding out if it has cover sills?
Edited by Corey96Williams, 20 September 2014 - 09:27 PM.
#18 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 20 September 2014 - 09:08 PM
No its easy to see from the outside if they have oversills fitted as they look like this
instead of looking like this
#19 Corey96Williams
Corey96Williams
  • 316 posts
Posted 20 September 2014 - 09:23 PM
Ah ok thanks  :gimme:
#20 MrIan
MrIan
  • 125 posts
Posted 21 September 2014 - 10:02 AM
Plus on oversills as can be seen in the pic above there aren't any drain holes as each lump you can see should be open to drain and create an airflow. Some over sills are thinner but they all cover the drain slots.
#21 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 21 September 2014 - 10:23 AM
Even if you were to create drain holes at each of the bulges water moisture will travel down to the floor edge and this is where the rust issues start. Yes you can fill will waxoyl etc etc but ultimately over sills ARE NOT the correct panel to use. They do not form the correct cross section when welded on for strength. The car was never designed with these panels so not part of the structural design process.
They have kept countless minis on the road over the years but in doing so have probably created more issues for the vehicle owners later on as we have seen on numerous cars on this forum.
#22 Carlos W
Carlos W
  • 10,115 posts
Posted 23 September 2014 - 02:40 PM
The other issue with oversills is they do not create the same box section as a narrow sill does.
I was looking for an image which I've seen on the forum before which shows this really well but I can't find it
#23 Corey96Williams
Corey96Williams
  • 316 posts
Posted 23 September 2014 - 07:12 PM
Is it worth holding on and not buying a Mini with cover sills? It's really hard to find a Mini without them...
#24 Carlos W
Carlos W
  • 10,115 posts
Posted 23 September 2014 - 07:27 PM
The problem is, you never know what's lurking underneath. There are lots of minis out there with the correct sills though
#25 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,853 posts
Posted 23 September 2014 - 07:44 PM
Absolutely. You'll know why after you've spent hours and lots of money replacing some.
#26 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 September 2014 - 09:05 PM
#27 Carlos W
Carlos W
  • 10,115 posts
Posted 23 September 2014 - 09:23 PM
Exactly like that! Cheers mate!
#28 Tupers
Tupers
  • 4,176 posts
Posted 23 September 2014 - 11:56 PM
My new saloon had a cover sill fitted when I got it. I ended up replacing the inner sill from the seat crossmember back to the heel board.
#29 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 September 2014 - 07:26 AM
Oversills -  :X
#30 miniweights
miniweights
  • 202 posts
Posted 18 October 2014 - 03:17 PM
Oversills! Don’t fit them if you want your Mini to retain its originality, and you want to fetch more money when you come to sell it. However, whatever sills you fit, make sure you inject them with wax something like Dynax S 50. Apparently this stuff is used in steel cavities on oil rigs, so it should be good enough for your Mini.
In theory, an oversill should preserve the sills from corrosion better than the original vented sills. This is purely because an oversill will retain moisture longer than original vented sills. It’s a fact that when steel is repeatedly exposed to water, and then allowed to dry, this speeds up the corrosion. If steel is immersed in water, and not allowed to dry, then the corrosion is reduced by a considerable amount. I carried out a test quite some time ago using a couple off-cuts of seam trim from my Mini.
Before carrying out the test, both pieces of steel was first cleaned with brake cleaner to ensure both pieces had nothing to protect the steel. One piece was placed in a container, and immersed in approx ½” of water, and the other piece placed next to the container (not in water, but exposed to weather in August 2012).
The picture below is 24 hours later
The picture below is 48 hours later
The picture below is 48 DAYS later, I had to remove the piece of steel from the water (pictured on the right) to show the condition.
The picture below is exactly ONE YEAR later. I think you get the idea now.
rust-test-12th-aug-2013-one-year-after_z
So if an oversill retains moisture, it will probably last longer than a vented sill. Personally, I believe a lot of the corrosion discovered beneath an oversill was there before the sill was welded on, and not necessarily caused by the oversill it self, but there because someone wanted a quick fix and couldn’t be bothered to fix things properly.
I personally fitted oversills to my Mini, simply because I’m not particularly bothered about originality or resale value. Providing the sill is welded at the lower point approximately 5” down from the sill seam lip, then the original strength should be retained. I believe a non vented sill (oversill) adds strength to the structure because it has metal throughout the length of the sill, as opposed to the original sill with vents.
So, in my opinion, if you want to retain originality and or resale value, then fit the original vented sill. If you’re not bothered either way, then I don’t see a problem with oversills, providing you weld approx 5” down from the sill seam lip. If like me, you intend to use your Mini on stage rallies, and it’s strength you’re after, then fit the full 9” sill, and weld along the bottom as well as 5” down instead of cutting it off. Don’t forget to add a few drain holes at the bottom of the sill to allow condensation to drain, you don’t want to carry around unnecessary weight.
I guess, if vented sills were a good idea, then I would expect modern cars to have them, but they don’t.
Anyway, we are all entitled to have an opinion, so I thought I would add mine :-)
