Oversills, What They Are And Why You Want To Avoid Them
195 replies to this topic
#1 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,853 posts
Posted 15 September 2014 - 10:24 PM
It occurred to me the other day that although there was a few previous threads giving some coverage to the subject, there was no 'one stop shop' for information on oversills.
Oversills, or 'cover sills' are a sadly regular bodywork phenomenon. I have in fact never managed to buy a mini that didn't have them, most people fit them for the sake of 12 months MOT, some fit them in error and a few people fit them thinking the problem is water getting into the sills, whereas in fact the sills are vented for the purpose of moisture being able to exit the sill.
Oversills block the venting, and thus moisture builds up and rots the structural parts of your car from the inside out. I bought a project car recently and it came with oversills. I'd already fitted proper narrow heritage sills onto a different Mini so i used this opportunity to demonstrate to other mini owners what the difference is. This is a shell turned on its side, with the correct vented narrow sill fitted:
This is a photo of an oversill panel courtesy of W&P. As you can see, its wider and pressed to take into account the original vents and weld line. The name 'over sill' coming from its role of going over the original sills!
Attached File  Classic-Mini-Magnum-Panel-Lh-Outer-Extended-1015754026.jpg   29.58K   2 downloads
And this is how things look when you remove them again (same car as first picture...!)
I just wanted to put this pictorial together to educate people out there as buyers and budding bodyworkers because oversills either mean the car has, or will have, hidden horrors. A quick repair it may be but down the line it will significantly damage the structure of a car, as well as its value, especially when you have to sell it needing all the welding ive just had to carry out.
I hope this helps any future buyers or restorers and if it stops at least one car from the peril of sill bodges then I've succeeded! Feel free to share and ask any questions if you should so desire.
Edited: Replaced out of date photo's.
Edited by Down&Out, 11 June 2024 - 08:11 PM.
#2 Cooperman
  • 23,322 posts
Posted 15 September 2014 - 10:36 PM
Here is my current 850 project with the horrible oversills removed:
and repaired with M-Machine inner & outer sub-assembly:
#3 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 15 September 2014 - 10:58 PM
I've seen the mess that the oversill did to the shell in the original post, first hand, that picture was very kind to how it actually looked in person. That area was a state, all because of one panel
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 September 2014 - 11:39 PM
This was a good idea putting this up on here. It is surprising how many Mini owners do not know what an oversill is or how to spot it.
I have lost count of the amount of rebuild threads i have read where the OP has put up pictures of the car they are doing and subsequently have fitted oversills.
People point out the fact that they have been fitted and the OP doesn't seem to even know what is meant by the term oversill.
I don't understand why they are still available? I think it is a complete waste of time fitting them for the sake of a few quid. Especially as Mini's are not the strongest car in the wrld. They need all the help they can get, not a piece of metal that is designed to fit over the top of the rusty remains of the original sill.
Daft..
Thanks for this thread down&out, I think it should be pinned to help others out.
Ben
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 16 September 2014 - 04:37 AM
We'll look at getting this pinned
#6 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 16 September 2014 - 06:24 AM
Nice write up. If only there was something like this when I bought my second mini. Damn that thing was a mess under them
#7 stevearch0
stevearch0
  • 310 posts
Posted 16 September 2014 - 06:50 AM
When I hacked the oversills off my project, the originals were in a bad way. Same consistency of ryvita!! Had three floors too!!
#8 MrIan
MrIan
  • 125 posts
Posted 16 September 2014 - 09:26 AM
Also those that don't repair their own cars need to watch out, i've seen a few restoration jobs done in garages advertising their restoration services on the internet with pictures clearly showing oversills fitted during the restoration. Yes they might have removed the old sill but they've stuck an oversill on with no drain holes to rot out anything in the area.
#9 geoff-d
geoff-d
  • 468 posts
Posted 16 September 2014 - 12:08 PM
I fitted oversills to 1 of my cars about 4yrs ago no problems. The trick is to cut the holes into the moulded bump part before fitting also removed old cover & original sills 1st
#10 MrIan
MrIan
  • 125 posts
Posted 16 September 2014 - 01:59 PM
Yes it is very easy to make them drain by cutting slots but then also there's a lot of floorpan covered up by the wide type of oversill. Again it's the people that don't know that are at risk of wrecking the future of their own car by repairing it with these. The wide ones are by far the worse repair panels i've ever seen by allowing the repairer to cover rust n rot in the floor. If it's not rusty when you fit them it soon will be. The original sill runs onto the floorpan by what? an inch at the most? the wide cover sill as shown above runs onto it what? 4-5 inch ? that's 4 - 5 inch of floor and trapped moisture in the lap joint created. Sorry but a bit of a sore point with me as i'm removing oversills from my Jet Black at the mo !! flippin things !!
#11 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 16 September 2014 - 02:11 PM
Is it worth pointing out about converting oversills? Im sure ive seen people cut 3-4 inches out of oversills to turn them into normal sills.
#12 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,073 posts
  • Name: Neil
Posted 16 September 2014 - 02:19 PM
The biggest issue with oversills other than the rust issue is they form the wrong contour cross section and in doing so are not as strong as the original short sill. You can cut as many vents as you like in an oversill but as mentioned its the section right at the bottom where the sill welds to the floor that cause a lot of damage.
I had them on my Clubman. The old sill was cut off so no issues there but even though they had only been on for a short period of time there was water / moisture in the bottom which has started to attack the floor pan. Yes you can pump them full of a Waxoyl based product but if you are doing a proper job on your car then do not fit them. They are not correct, its as simple as that.
#13 RossKnight
RossKnight
  • 2,539 posts
Posted 16 September 2014 - 03:05 PM
Might as well just fit normal sills?
#14 1984mini25
1984mini25
  • 8,785 posts
Posted 16 September 2014 - 04:43 PM
You can see from the pics, just how rusty the oversill I paid £100 for to be fitted at a mini specialist in Northampton to get mine through it first mot, back in 05.
The oversill was only on the car for a MONTH and had been painted/under sealed on the outside. Its not until I went to patch the floor, thinking the sill was done and fixed 'properly' I end up having to remove the oversill and redo and weld on a proper sill instead.
2134183278_9f3fb822f0_z.jpg?zz=1
And you can already see the tell tale signs of rust starting along the oversill to floor weld.
2184628549_0b00a25901_z.jpg?zz=1
Edited by 1984mini25, 16 September 2014 - 04:44 PM.
#15 Bubblebobble
Bubblebobble
  • 661 posts
Posted 16 September 2014 - 07:00 PM
