I removed the top of the air box first, and undid the jubilee clip holding the air pipe to the lid.
I then pulled the air pipe going from the box to the turbo out. The air box is held in at the bottom left corner by one screw. It also has little feet that fit into some rubber stoppers.
The picture shows the bay without the filter.
To the right is the loose pipe leading to the turbo. On the left you can see a down pipe coming from the turbo. That needs to go.
this is the bottom of the down pipe on the left. It is held into a plastic tube by a c clip.
The top of the down pipe has a jubilee clip.
this is were the down pipe should be. You can see the plastic tube that it fits into. I removed this with great difficulty as the rubber hose was very tight around it.
There is also a smaller hose attached to the tube which had to go also.
You can just see the head of the tensioner bolt on the right of the picture.
Not super detailed I know but when I go back to it ill take moreeee pics.
Thanks guys for reading!
