same :)I made my own captive nuts, by welding the original nuts on
I'm going to do the same next time!
That is the best thing to do.
Another tip is to make the holes in the sub-frame slightly larger, say 3/8", to make lining up the mounts easier. Then just use slightly larger washers under the bolt heads. Engine position is not critical to +/- a couple of mm.
