Replacing Engine Mounts
18 replies to this topic
#1 samt88
samt88
  • 445 posts
Posted 13 September 2014 - 06:18 PM
My engine mounts are completely buggered and in dire need of replacement so I was just wondering how big of a job it was?
Also, I was hoping to drive 600 miles, round trip, tomorrow - will it be safe to drive until I can get it sorted next week?
Sam
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 13 September 2014 - 06:43 PM
It's not a big job but it is fiddly, depends whether your mini has the side mounted radiator, if so then it is a drain down and radiator out job and the other side is tight to get the mounts on and off because of the clutch housing. It is about a 3-4 hour job if everything goes right. Personally if they are completely buggered as you say I would not risk a journey and certainly not of that distance.
#3 robminibcy
robminibcy
  • 1,516 posts
Posted 13 September 2014 - 06:51 PM
It will be safe in that the engine won't drop out yes! But it wont be pleasant! I would use the mini but just take your time accelerating and change gear smoothly as possible. A journey of that distance I guess is mostly motorway which won't really put a great deal of strain compared to round town.
#4 samt88
samt88
  • 445 posts
Posted 13 September 2014 - 07:37 PM
Ok cheers guys, I'll get it done!
#5 miniboy1993
miniboy1993
  • 274 posts
Posted 14 September 2014 - 01:58 PM
I just done mu engine mounts pretty easy to be honest :)
#6 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 14 September 2014 - 02:06 PM
Every mini I've ever had needed the motor mounts replacing. On two of them one of the mounts was in two pieces. Certainly not dangerous and if you have a magic wand gear leaver it can be really difficult to get into second or fourth if the engine moves (mine did!) it also depends on the radiator fixing. If you have the later fixing it's not so bad but the earlier one is a real pain.
It's MUTCH easier with two people. When fitting the new mounts don't tighten everything up until ALL the bolts are in loosely. Don't use the mounts with captive nuts, they can be a nightmare if you start a bolt cross threaded, or when you come to change them again in a few years time.
There's lots of threads on here with advice.
#7 racingbob
racingbob
  • 3,061 posts
Posted 15 September 2014 - 02:47 PM
get the genuine rubber engine mounts
#8 Cooperman
  • 23,278 posts
Posted 15 September 2014 - 03:09 PM
+1. And never fit the ones with the treaded inserts pre-fitted!
Just use original quality mounts as supplied by Mini Spares. Grease the face which goes onto the sub-frame before lowering the engine, one end at a time, to make it easier for the mounts and holes to line up.
It really is not that difficult.
#9 samt88
samt88
  • 445 posts
Posted 19 September 2014 - 01:22 AM
Ah, the guy who's replacing it said he would use the more modern ones. Why do you say genuine rubber?
#10 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 19 September 2014 - 05:41 AM
Because these chaps know better...
#11 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 September 2014 - 06:13 AM
Because the genuine ones were designed for the job...
For someone who has removed and fitted his fair share of engines, you want to see the trouble I've had with some 'quickfit' replacement mounts, cross threaded captive nuts, captive nuts which are no longer captive, poly mounts which literally fall apart when removed and don't get me started on quick release mounts..
#12 Dusky
Dusky
  • 5,322 posts
Posted 19 September 2014 - 07:14 AM
I made my own captive nuts, by welding the original nuts on :P
#13 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 19 September 2014 - 07:23 AM
same :)
#14 racingbob
racingbob
  • 3,061 posts
Posted 19 September 2014 - 08:24 AM
minispares do the original rubber ones
you can see the difference about £8 each
#15 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 19 September 2014 - 06:56 PM
same :)
I'm going to do the same next time!
