hi guys, i recently had a split hose on a drive so all my coolant was lost... replaced the hose, coolant and bled the system until the heater was blowing hot (took a few times to get the air out) all the hoses were getting hot to touch.
so it was blowing hot while i had it on idle... i thought id go for a test drive to confirm...
basically now, when at idle the heater blows cool air but while revving or fast idle i get hot air out.
could it be more air in the system?
an obstruction on the hoses?
weak water pump? (there does appear to be a slight whine from the pump area, though not sure its the pump. it does increase with revs though)
ill check the belt and keep at bleeding tomorrow but whats the best way to flush the system?
thanks
