Copper Grease On Bolts Or Clean Thread?
35 replies to this topic
#1 se_juggles
se_juggles
  • 1,043 posts
Posted 04 September 2014 - 11:57 AM
Alright mini peeps.
I am just wondering what bolts i should/shouldn't be using copper grease on if any?
There is alot of different views on copper grease the main one being: "if copper grease is applied to the thread it changes the torque settings as there is reduced friction". I just wanted to know what other people's views are on this subject and if there are certain bolts i should not use it on i.e wheelnuts.
What do i do about torque settings? (just tighten till i cant tighten anymore (not with a torque wrench of course lol))
Does it matter if using them on brake parts as i have read it can cause problems because of the heat?
Its mostly just suspension parts i am working on at the moment, putting the rear and front subframe assembly together.
Thank you in advance for your help.
SE
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 04 September 2014 - 04:50 PM
You will indeed get differing opinions on where and when to use anti-seize compound.  I will offer my suggestions but that is all they are... suggestions.
I use it any place that is prone to seizure from corrosion.  Specifically: rear subframe bolts, thermostat housing studs, exhaust fasteners including manifold studs, and though some will cringe when I say it... wheel studs and the contact surfaces between the inner surface of the road wheel and drum/flange on the car.  I also apply a tiny bit to spark plug threads.  Other places where I use the stuff I don't think about... I just apply it if I find corrosion starting to stick the bits together.  Some places I prefer not to use anti-seize and instead I use Loctite to both protect the threads and secure them.  EDIT:  (i.e. Places subject to vibration that might loosen a fastener are places I would use Loctite instead of anti-seize).
Any lubricant applied to a thread will change its behavior when tightening so you may want to adjust the torque a bit but I typically do not.  Anti-seize is not as good a lubricant for threads as something like assembly lube for which you do adjust the torque values.
Edited by dklawson, 04 September 2014 - 04:52 PM.
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 04 September 2014 - 06:27 PM
I agree with doug!!
#4 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 04 September 2014 - 09:00 PM
+1 :-)
#5 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 04 September 2014 - 09:36 PM
I have been taught to assemble dry unless otherwise stated or in a non critical area I guess it wouldn't matter so much
#6 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 04 September 2014 - 09:38 PM
I agree with doug!!
Really? I thought you "put it everywhere" if I'm not mistaken
#7 se_juggles
se_juggles
  • 1,043 posts
Posted 05 September 2014 - 04:05 PM
Thank you that is alot of help. just gotta get a full nuts and bolts kit now.
I agree with doug!!
OH MYYYYY!!!!!!!
#8 Stevie W
Stevie W
  • 1,203 posts
  • Local Club: P&SMOC
Posted 05 September 2014 - 04:17 PM
+1 on what Doug said!
#9 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 05 September 2014 - 04:20 PM
I agree with doug!!
OH MYYYYY!!!!!!!
I put it on any new bolts, wheel hubs and subframe bolts
#10 Stevie W
Stevie W
  • 1,203 posts
Posted 05 September 2014 - 04:30 PM
I did use copper grease on the front lower shock absorber pins that run through the top susppension arm, as I remember them being a right nightmare to remove during restoration!
Admitedly, I won't need to remove them again for a while, but where theres an application that doesn't directly affect any torque settings, I think using this stuff is accaeptable.
My 2009 Hyundai i30 came back from a service recently and the wheel nut studs had been given a coating of copper grease!!!!
Cheers, Steve.
#11 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 05 September 2014 - 05:25 PM
Cheers, Steve.
Yeah thats fine
Your Hyundai having copper grease on wheel studs is a daily occurance, the torque ratings are higher to compensate :)
#12 Gremlin
Gremlin
  • 2,142 posts
Posted 05 September 2014 - 06:14 PM
Torque settings should be lower to compensate as the copper grease lowers the friction on the threads
#13 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 05 September 2014 - 07:44 PM
Cheers, Steve.
Yeah thats fine
you really are a
Edited by Rob Mac, 05 September 2014 - 08:56 PM.
#14 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 05 September 2014 - 08:18 PM
This thread is funny.
Please don't apply a higher torque setting if you're using copper grease, you should lower it if anything.
#15 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 05 September 2014 - 08:23 PM
Me? A clown. Hahaha
Well admin can now suspend my account!!! Sick of the way people are on this forum.....
