Mini R1
7 replies to this topic
#1 josh.evans
josh.evans
  • 1,439 posts
Posted 03 September 2014 - 06:47 PM
Hi here's my mini r1 it has the lynx ae r1 kit fitted along which has a atb limited slip diff and is running and accusump to keep oil pressures good when using on track.It has been re jetted at tts over in Silverstone which its running around 110bhp at wheels. since the kit has been fitted I have done around 500miles so everythings pretty much new. The engine has done around 18000 miles. It is the 5jj carbed verion.it has had brand new clutch plates and steel plates oem. the car weighs in at 538kg without passenger seat so it is a very quick fun car to drive. only reason for sale is that I have started another project and this never gets used... which is a shame a lot of money and hard work has been put into this. heres a list below of whats on the car.
its moted till April 2015 and taxed till October 14
£8500 ono
Mini checkmate 1990
5jj r1 engine running 110whp tts jetted, modified top water pipe, stick coil conversion neater install.
r1 clocks temp guage works along with all indicator and headlight dash lights
acumen gear indicator
2011 big bang voltage regulator
complete lynx ae r1 kit with atb lsd and electric reverse
minispares alloy rad
accusump
facet silver top fuel pump
filter king fuel regulator
modified throttle pedal longer throw for bike carbs
brand new minisport front hubs
minisport alloy 4pot 7.9 brakes
rear minifins with new shoes
refurbed radius new pins bushes etc
refurbed subframes
rear subframe polybushes
front solid subframe mounts
internal brake lines
internal fuel line
internal battery light weight
cobra imola fibreglass buckets
4 point harnesses
6 point welded roll cage
aluminium dash and rear shelf
acw plastics poly windows
lightened steel doors
omp steering wheel
wipac free form headlights
mk2 rear lights
mk1 front grille and surround
front and rear minisport hilos
front minisport camber kit
minisport rear camber brackets
spax adjustable red shocks all round
10x6 weller wheels with yoko ar032r tyres
pressed number plates
arc angles, carbon roof, miglia arches, bumpers and bonnet
carbon fibre wing mirrors
think that's it may have missed few bits
heres the build thread too
http://www.theminifo...ect-no2-the-r1/
#2 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 04 September 2014 - 03:45 PM
Wow if I had that amount of money I'd buy it straight away, if you need to get rid of it ASAP I'll come pick it up right now I'm offering £1000 ;) only joking good luck with the sale.
#3 samsfern
samsfern
  • 5,243 posts
Posted 05 September 2014 - 10:08 PM
Would you take a modern car in as part exchange and a bit of cash?
#4 josh.evans
josh.evans
  • 1,439 posts
Posted 06 September 2014 - 04:42 PM
Try me PM me
#5 love333
love333
  • 48 posts
Posted 08 September 2014 - 07:51 PM
very unlikely but would you be interested in breaking the mini? Glws
#6 josh.evans
josh.evans
  • 1,439 posts
Posted 11 September 2014 - 11:06 AM
Hi sorry will only be sold complete thanks josh
#7 VulcanBomber
VulcanBomber
  • 170 posts
Posted 11 September 2014 - 12:52 PM
Do you know the full history of the car?
#8 josh.evans
josh.evans
  • 1,439 posts
Posted 12 September 2014 - 08:57 PM
Hi yes I built it...
