1986 Chelsea - At Long Last
80 replies to this topic
#76 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,850 posts
Posted 03 October 2024 - 06:24 PM
Well, i ended up doing this:
I decided that given it was only sitting on its lower mounts and i wanted to paint the bulkhead, i may as well pull it out the way. it certainly made access a lot easier!
Redid all the bits i wanted to redo...
Now begins the big reassemble. After a serious wet sanding of course..
#77 Down&Out
Down&Out
  • 4,850 posts
Posted 07 October 2024 - 06:06 PM
Well with the help of some friends this has moved along a little!
Engine is now back in and i've done some important jobs like fitting the tank and running the brake/fuel lines.
I also finally got round to getting the tyres fitted to the wheels...
A bit more paintwork to do in the form of wheelarches and bumpers, but i can nearly call it 'painted'.
More to follow soon.
#78 MatthewsDad
MatthewsDad
  • 805 posts
Posted 07 October 2024 - 07:33 PM
Great work, looking good
#79 Down&Out
Down&Out
  • 4,850 posts
Posted 01 March 2025 - 09:24 PM
Hello all,
I've been a bit lax with getting on with this. Busy welding up other vehicles, however my friends came over and gave me a hand getting it moved along a bit. As of today it has a working clutch, it runs and moves under its own power.
Still have brakes, plumbing, wiring, assembly etc to do, but its closer than its ever been!
#80 Down&Out
Down&Out
  • 4,850 posts
Posted 25 March 2025 - 10:08 PM
Well, a small update...
I've fitted a sexy S-Can fog/reverse bracket. I've always hated the massive box they fitted in the 80s as a fog light. It still requires one for MOT legality and its nice to have for visibility, so i shelled out on one of these. i had to drop the tailipipe a bit by cutting and welding but it ended up being worth it!
I also resprayed the arches body colour as was always the plan. I think they look better colour coded.
I've been pushing to get this on the road because its coming up to a year since i started work on it again, and upon trying to bleed the brakes it leaked fluid everywhere... Its a brand new cylinder but its laid dormant for some years so modern rubber has perished as usual. Rebuild it with a seal kit today but we shall see if that has actually worked or not...!
I polished the front end and fitted the windscreen today,  almost feeling like a car. Just needs brakes and a bit more assembly but maybe i'll have an MOT before its 19th anniversary in my ownership?
#81 Down&Out
Down&Out
  • 4,850 posts
Posted 31 March 2025 - 09:06 PM
Well, the seal kit didnt work. I did a full bleed and it chose the completion point to dump its fluid in the footwells (again!).
So with that having happened, i decided to fit some shiny bits...
Another minispares order inbound, hoping this is the last one.
