hi guys,
My mini is a 1978 mini and in that year they fitted what is possibly the worst braking system british leyland ever fitted to a car and I've had nothing but problems for the past 2 years.
Enough is enough and I've taken it off the road to re-do the whole system from front to back and I'm wondering what the best system is for a 7.5inch disk set up?
I've already purchased these from minisport at the weekend for the rear link, its the 3/4 bore brake cylinders instead of the current 1/2 inch bore as these don't seize up anywhere as easily.
I intend to get the minisport conversion kit with the 4-pot callipers and mintex pads for the front along with steel braided pipes at each wheel.
Its at this point I get stuck as I know there were various set-ups installed in terms of master cylinders and dual line and single line braking and I don't know which type of system is the best one to go with and I don't know what type of brake bias valve I should get to reduce the pressure for the rear wheels etc etc.
so if anyone can offer advice then please do
thanks, Adam
also just thought, I would prefer to not get a servo as my mini will be getting modified to a point and to keep some of its history I will be changing it back to left hand drive in a few years when I can get classic insurance
Edited by Mini Mad Drakeley, 01 September 2014 - 06:19 PM.
