I've recently fitted a second-hand period Smiths temperature gauge into my 1975 Mini. The Mini has a centre binnacle with a voltage stabiliser unit. I don't know the history of the gauge but from reading a forum thread from January 2010 I wonder whether it is a pre-1965 gauge and therefore doesn't use the voltage stabiliser. The fuel gauge is working perfectly.
I currently have a standard GTC101 sender unit fitted which I've checked using a multimeter and a beaker of hot water. The resistance of the sender unit changes with temperature so I believe that it is working, and the sender unit has not been fitted using PTFE tape. I've currently connected the gauge to the I terminal on the voltage stabiliser and it is earthed effectively (the illumination light works which uses the same earth). When I switch on the ignition the needle moves up instantly to the "Cold" position where is flickers occasionally. However the needle does not move up from there when the engine is run up to temperature. When I short out the lead from the sender unit the needle immediately goes to "Hot" so I believe that the wiring is correct.
I now wonder whether if it is a pre 1965 gauge, I need to wire it directly into a 12V supply and use a GTC104 sender unit. I've attached a photo of the gauge. Can anybody help me please?
DSCN6946.JPG 63.9K
3 downloads
