This is not my car. I am helping a friend with the suspension on his '78 Mini 1000.
He wants to install new rubber cones and a set of Hi-Lows. The method I used on my '64 when doing the same is not working. We are unable to remove the top arm pivot pin from his car to allow removal of the top arm and fitting the new cone.
This is what we have done...
The old cone was compressed so we were able to remove the old trumpet. The rubber cone is still trapped in the subframe tower but it is unloaded. Therefore, the top arm is unloaded.
We removed the rear nut on the top arm's pivot pin.
We removed the two 1/4" bolts holding the diamond plate securing the top arm pivot pin to the subframe.
That's when things fell down. The top arm will not move forward. After levering and prying for a while we gave up and removed the big nut from the diamond plate so we could verify if the pivot pin could spin in the needle bearings. It can. So the pin is free to rotate but we cannot move it forward to extract it. It won't move the tiniest bit. Again... the pin is free on both ends and it will spin in the arm but we cannot pull it forward and out of the subframe to free the top arm.
We removed the Zerk fitting on the top arm and sprayed penetrating oil into the arm (multiple times) only to see a flood of rusty, dirty penetrating oil come out. My gut feeling is that the pivot pin and needle bearings must be horribly rusty and/or the needle bearings have worn grooves into the pin preventing us from slipping it out.
Are there any suggestions for getting the pin out so we can free the arm? Are we going to be forced to cut the arm to extract it and then replace it and the pin with new? We have pushed, prodded, and pried every way we could think of. All advice is welcome.
