You haven't got a compressor have you mate?
If you did I would've posted my air ratchet over
Posted 23 September 2014 - 05:21 PM
Posted 23 September 2014 - 05:24 PM
No unfortunately.
I am dreading putting the turbo and that bit of exhaust back.
I think it's supposed to go in and come out from underneath but to do that, you need to take out the subframe and 1 driveshaft. Not doing that, no way!
Posted 23 September 2014 - 05:26 PM
It's a shame it's on the IOW and not in Sittingbourne.
Posted 23 September 2014 - 06:00 PM
Posted 23 September 2014 - 06:20 PM
Don't let it beat you mate
Posted 23 September 2014 - 06:52 PM
ill try not to!
Posted 24 September 2014 - 11:39 AM
i got the clips off now..
Posted 24 September 2014 - 11:55 AM
Can Hylomar Blue be used on manifold and turbo gaskets during assembly?
Or am i stupid?
Ben
Posted 24 September 2014 - 12:09 PM
Posted 24 September 2014 - 12:17 PM
Thats a big fat no.....
Or am i stupid?
Ben
Posted 24 September 2014 - 12:44 PM
Thanks guys..
Just had a tube lying round and wondered
Ben
Posted 24 September 2014 - 02:49 PM
Ok, so just discovered that the sensor that i broke taking the manifold off is the MAP sensor. As far as i can figure, it measures air flow in the inlet manifold and tells the ecu how much fuel to inject.
The rubber hose that comes off of the MAP sensor goes onto the inlet manifold and when i removed it, i noticed that it was very blocked to a point where i couldn't blow through it.
What i need to know is would this tell the ecu to add more fuel or less? Obviously, it isn't measuring any air flow if it blocked....
Ben
Posted 24 September 2014 - 03:43 PM
So to summarise, i thought i would list the original symptoms and what problems i have found to get opinions on whether they coincide.
Symptoms:
Very little power from engine.
Lots of exhaust smoke from the tailpipe and from behind the engine
engine running lumpy/shaking around.
Chugging on tickover and when revving until passing 1500rpm where it clears up
Occasional fast clatter from turbo when revving engine
Problems found:
Massive crack in exhaust section that links the turbo to the cat
One injector dry and rusty
Blockage in the hose that links the MAP sensor to the inlet manifold
Blockage in the hose that links the dipstick vent box to the bottom of the crankcase
Oil in the inter cooler and pipework
Minor axial play in the turbo turbine
inlet manifold coked up and wet with fuel?
Air filter very black
EGR valve wet with fuel? Not sure of it operational but have bypassed it by turning the valve 180 degrees.
So do the symptoms and problems found add up? Is there anything else that could be causing the problems that i may have missed?
Obviously, i plan to sort the problems listed on the 'problems found' above.
Ben
Posted 24 September 2014 - 04:21 PM
A fudged map sensor will over fuel. Try cleaning it and running with it disconnected. It may be smoother. Connect it up and see what the difference is.
A MAP sensor is " manifold absolute pressure sensor The map sensor provides instantaneous manifold pressure information to the engine's ECU. The data is used to calculate air density and determine the engine's air mass flow rate, which in turn determines the required fuel metering
