Renault Megane Scenic 1.9Dci Engine Swap
520 replies to this topic
#61 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 September 2014 - 11:35 PM
So is there anything you can do in this situation or do you just have to wait for it to stop?
#62 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 September 2014 - 11:39 PM
found out......
http://en.wikipedia...._engine_runaway
#63 matt050990
matt050990
    I have upside down nipples
  • 1,199 posts
  • Local Club: Currently Ridin' Solo :)
Posted 10 September 2014 - 04:59 AM
That happened to.mine on my way home from work. Drover 120 miles home and it went about 1 mole from my door. Pulled over at side of the road but the car wouldn't stop revving it's nuts off! Filled the whole dual carriageway with smoke! Pretty scary really as was waiting for it to go BANG!
#64 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 10 September 2014 - 05:59 AM
Happened to me to once is a work recovery truck. Needless to say it scared the life out of me as I was on a dual carriageway.
Managed to get it to work where it it promptly blew up.
#65 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 10 September 2014 - 06:05 AM
you have to try and stall it
#66 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 September 2014 - 11:35 AM
Just took it for a drive and it smokes like bileo and sounds like a Gatling gun at low engine speeds. Once you get going it sounds ok but still the smokes.
Tick over is a bit better but still not 100%
It pulls away ok in 1st gear but when you change to 2nd it feels really sluggish and takes ages to get the revs up.
I'm thinking about just getting rid unless i can come up with something soon.
Ben
#67 Carlos W
Carlos W
  • 10,114 posts
Posted 11 September 2014 - 05:10 PM
Give it a good run
#68 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 September 2014 - 09:15 PM
Just had this advice from a member on the renault forum.
From the video I'd say the crankcase breather is blocked. I wouldn't run the engine too much in this condition due to pressure build up that could blow seals and gaskets. FWIW, it's easier and simpler just to replace the breather stem, they're cheap enough.
Does this sound like a likely cause to my problems?
Ben
#69 Badboytunes
Badboytunes
  • 1,615 posts
Posted 16 September 2014 - 06:51 AM
It could be, ...... If the crankcase cant vent then the pressure has to go somewhere. Ford CVH engines are known for this problem too.....
#70 sledgehammer
sledgehammer
  • 3,098 posts
Posted 16 September 2014 - 07:31 PM
Ben
Yep that could cause the problem
something to remember is the exhaust probably has oil / fuel mix in it - so it will smoke a while even after fixing it
do you know for definite the fuel in the tank is good ?
someone at work runs his jetta on sump oil - it runs ok - but a modern diesel won't run properly at all -
wondering if someone tried to run it that way ?
#71 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 16 September 2014 - 07:52 PM
Ben
well it was previously owned by a woman and she took it to the same garage to have every bit of work done right down to fitting wiper blades and bulbs. I have the receipts to go with it so i expect it should be ok?
It has literally only just come off of the road too so not even been sitting.
I have removed the crankcase breather and found a massive blockage in the rubber hose that had made it air tight, Took me 20 mins to shift it!
Still i cleared it, put it all back together and it's still the bloody same! Made no difference at all.
I just wish i could fix the smoke coming fro under the bonnet. Someone on the Renault forum suggested it could be a fractured flexi pipe on the exhaust allowing the exhaust smoke to fill the engine bay which kinda makes sense but they are a quiet bunch over there and i'm lucky to get a reply every other day.
I think i really need to get all of the breathers off, the inlet manifold, the turbo and all associated pipework and inspect the lot. There must be another blockage somewhere.
Like i say, i know the turbo is sucking well as if you put your hand over the induction pipe, it tries to suck your hand up the tube! the turbo actuator moves freely and easily.
Just need to get to the bottom of the chugging because once that's fixed, i can give it a good blast and see if that clears the smoke??
Ben
#72 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2014 - 12:05 PM
Right, another day on the bus and another problem :(
I have found the dodgy injector and replaced it with a good second hand one. It now does not misfire but is still a bit rough on tickover and there is now a noise on tickover. You can hear it in the video below. Its like an irregular drumming like someone banging to the beat on the side of a drum.
I need to know what that noise is as it holds the key to fixing it i think because as soon as you rev it and that clears, it revs beautifully and clearly and there seems to be alot more power when driving it than before.
The smoke is still there under the bonnet but nowhere as near as bad and it seems to be getting less and less the longer i run it.
http://vid119.photob...zps456c4a93.mp4
Any more ideas anyone?
Ben
#73 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2014 - 12:21 PM
Ok so another discovery i just made is that the new noise seems to be coming from within the inlet manifold. If i pull off the intercooler hose that  goes up to the inlet manifold it pops and bangs out the end of it. Its the same noise you can hear on tickover but amplified with the hose off. I have tried to capture it in another video.
http://vid119.photob...zpsa43f91f7.mp4
Any ideas?
#74 sledgehammer
sledgehammer
  • 3,098 posts
Posted 21 September 2014 - 01:30 PM
sounding like an inlet valve stuck / burnt ?
dumping un burnt fuel into inlet manifold
just a guess thou
can you do a compression test ?
that is quite a chug
Edited by sledgehammer, 21 September 2014 - 06:07 PM.
#75 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 September 2014 - 01:43 PM
When i took the knackard injector out, the end of it was dry and rusty.
I'm thinking of paying a garage to just take a look and see what it is. There is a very good one nearby that may do the testing for me. Ill ring them tomorrow.
Ben
