It's a lively engine isn't it! Where's all that smoke coming from? Is it oil burning?
Renault Megane Scenic 1.9Dci Engine Swap
#31
Posted 02 September 2014 - 04:36 PM
#32
Posted 02 September 2014 - 04:41 PM
I'm not sure where the smoke is coming from, it's been suggested that perhaps it's a split pipe.
I took the EGR valve out and although all of the pipe work is covered in heavy oily slime, it works fine.
It's probably going to end up being injectors. Someone told me they have to be programmed to the ECU.
It's going to be fun and games.
Worth it i hope though as it's in great condition and very comfortable too
#33
Posted 02 September 2014 - 04:44 PM
Fingers crossed. Not chucking anything nasty out the back is it?
#34
Posted 02 September 2014 - 04:46 PM
I don't think faulty injectors are causing the smoke unless they're leaking fuel
#35
not really, just a bit of black smoke when you boot it. Not that you can really boot it right now!
#36
Posted 02 September 2014 - 04:47 PM
Plan of attack tomorrow will be, ductwork and airboxes off and major clean up and check
#38
Posted 02 September 2014 - 07:11 PM
It's got to be called Moxie
#39
Posted 02 September 2014 - 07:12 PM
More like poxie...
haven't decided a name yet. Ill leave that to the better half.
I don't usually bother with names personally
Good idea though
Ben
#40
Posted 02 September 2014 - 09:20 PM
Edited by samsfern, 02 September 2014 - 09:24 PM.
#41
Posted 02 September 2014 - 09:29 PM
#42
the Injectors on deisels normall sit on a copper O ring, somtimes these can go and it'll chuff oily crap out and run like pants, often sounds like a really leaky exhaust manifold gasket.
#43
Posted 02 September 2014 - 09:35 PM
It has been suggested that there might be a split pipe somewhee causing all that smoke from under the bonnet. Il strip it all out tomorrow and see what's what
Hope it's not the turbo
#45
Posted 03 September 2014 - 12:38 PM
Looks to me like the Turbo gone mate!
Exactly what happened to my 1.96dci.
Fitted a new turbo and it blew within 30 miles.
