Renault Megane Scenic 1.9Dci Engine Swap
520 replies to this topic
#331 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 25 February 2015 - 09:06 PM
Hope all goes well Ben
#332 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 February 2015 - 09:11 PM
Thanks mate
#333 sledgehammer
sledgehammer
  • 3,098 posts
Posted 25 February 2015 - 09:40 PM
about time you had some luck
esp with the work you are putting into it
fingers crossed
#334 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 February 2015 - 09:43 PM
fingers crossed
Cheers!
I'm sure it will be fine. I can't see what can go wrong really. Perfect running engine bolted in and hooked up. Simples...I hope
#335 MrBounce
MrBounce
  • 2,644 posts
Posted 25 February 2015 - 10:13 PM
I've just read all of this. I think you'll do alright out of this Ben. Well done for not giving up :thumbsup:
#336 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 February 2015 - 10:31 PM
Cheers!
I just hope it's worth it. I need this car to last me. i don't like keep changing cars and i can't afford to get a new car.
Once the engine is done, ill tart it right up, do all the bits and bobs and then look after it properly.
ben
#337 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 26 February 2015 - 07:29 AM
Quick question.
The coolant that was in the car is thick and green and the coolant i have got to go in is thin and blue.
Should i go out and buy green instead or run the car with plain water to flush it out and then fill with the blue?
I'm sure i heard you can't mix types and colours..
Mine has the pink in just to confuse matters.
#338 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 February 2015 - 03:48 PM
Today has been very slow progress due both to the horrendous weather conditions and a few problems i had.
I undid the castle nut on the n/s hub on the red one so i could get the driveshaft out and once i had undone the bottom ball joint, track rod and pulled it clear, i couldn't free the splines from the hub so i had to resort to this :lol:
Oh well, it's clear of the gearbox so it will do..
And i had an accident whilst jacking up the car which resulted in the car slipping sideways off of the jack so now i inly have this much room to work on the o/s
oops..
​Both engines are completely ready to lift out now. I was going to pick up the engine hoist this afternoon and try and finish with it quick enough to only need it for a day but i spoke to them and they have a deal where you pick it up friday lunchtime and return it monday lunchtime and only pay one day hire so i'm doing that instead.
Ben
#339 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 26 February 2015 - 04:58 PM
You might want to check the abs reluctor rings on the cv joints. Mine are fractured and give me an intermittant abs light.
If they are visibly poor then you might want to persevere with getting the driveshaft out fully to change them while you have it all in bits.
They fracture between the teeth and then the interference fit fails and they end up twizzing round and out of position.
#340 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 February 2015 - 06:11 PM
Thanks for that little nugget. Ill have a look and see and if they are fractured, ill check the ones off of the donor car if they are ok.
Is there anything else that you would save from the donor car as spares? anything that they are prone for so i can nab before it goes for scrap?
#341 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 February 2015 - 06:12 PM
I noticed that the MAF sensor on the donor engine was disconnected when i removed the air box. Is there any reason he might have disconnected it or could it have just come loose and fell off?
You have to take the big weather shield under the scuttle to get at it and it hasn't been off recently so i don't know.
Ben
#342 Badboytunes
Badboytunes
  • 1,615 posts
Posted 26 February 2015 - 08:13 PM
If removed, it could be because it has failed and he had poor running, especially in the lower rev range. These often ping up and EML if failed. Quite often, people disconnect them but fuel consumption will be increased.
Some more info can be found HERE
Keep us posted.
#343 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 February 2015 - 08:39 PM
Keep us posted.
Thanks for that link. It was a good read and lots of useful information too.
I will just connect it and see what happens. if it runs and drives perfectly then i guess it just fell of. If there is a problem, it will be the first thing i change.
#344 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
I think i'm going to move this to any other projects as it has turned into one!
#345 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 February 2015 - 08:45 PM
I went a bit OCD with my preparation for the refit  :lol:
