| kept going and managed to get the rest of everything off including the driveshafts, selector shaft, engine steady bar, the engine mount and gearbox mount.
It is just resting loosely on the subframe now so is ready to pull out tomorrow.
i did cut a corner though... I had to cut one of the starter motor wires as i just couldn't get in there to get the nut off but it don't matter as its on the loom from the scrap car.
So here it is all ready!
And a boot full of everything removed
Only one problem i can see and that is this.
That is from the donor car, the fuel pump is the same but it had a little box that the one of the fuel pipes directs through and it has a wiring plug that goes to it.
My car doesn't have it so i am guessing i would just remove that part and use my fuel pipe setup on it??
Here is my pump setup
You can see that the return pipe piggybacks onto the fuel pipe instead of that wiring block thingy magigy...
Any thoughts good people??
