Squirrel in sump!
The odds are long, but I'm a risk taker.
/me skips away to play in TMF's database tables.
Renault Megane Scenic 1.9Dci Engine Swap
#271
Posted 03 October 2014 - 04:48 PM
#272
Posted 03 October 2014 - 04:52 PM
To fix valves that aren't sealing you need to whip the head off and replace the head gasket anyway.
The fact that it runs better at higher revs may point towards a compression issue?
#273
Posted 03 October 2014 - 07:32 PM
You need to take the top engine mount off to take the cam belt off.
Maybe its even had a cam belt go and the pistons caught a valve and bent it just enough to make it not seat properly or stick but not enough to truly fubar anything. The f9q is an interference engine.
#274
Posted 03 October 2014 - 08:39 PM
Even replacing a valve isn't the end of the world. It will be evident if you take the head off and you'll know then once and for all. If its a valve, replace. If its not then cit your losses. Its still only time you've wasted. Not money.
Thanks for the advice mate.
What are you doing over the weekend?
#275
Posted 03 October 2014 - 09:07 PM
seriously just scrap it, the price of a head set, couple of valves, cam belt kit, water pump etc is more than the car is worth.
#276
Posted 03 October 2014 - 10:40 PM
Its not going to cost him anything to check, only his time
Edited by RossKnight, 03 October 2014 - 10:41 PM.
#277
Posted 03 October 2014 - 11:06 PM
Stop being a killjoy
it's like watching a spider trying to climb out of the bath, you just know it's never going to happen
#278
Posted 03 October 2014 - 11:55 PM
well i'm not really in a hurry to so anything with it and i'm certainly not trying to prove anything. If it turns out it can be repaired on the cheap, then it will be a cheap car. If it's something really major and expensive, then it will be scrapped.
simple as that.
I don't even need it on the road now so if it sits out there for another month, then so be it. It's not hurting anyone.
On another note though, here on the Isle of wight, people often sell their car cheap if it fails an MOT for instance.
I bought a 2.0 HDI Citroen Xsara last year on a 51 plate for £150. all it needed was welding to the outer sills. It was and still is in perfect running order. If i Megane/Scenic or Laguna dci turns up cheap with out an MOT, then i have an engine.
A Vauxhall Vivaro was on there about 8 months ago that had damage to the rear and side. It was an early one so has the same F9Q engine. The bloke wanted £250 for it! Something like that would donate it's engine, i could sell any other bits and weigh in the shell.
I am keeping my eyes peeled anyway
#279
Posted 04 October 2014 - 12:45 AM
If your paying someone 300 quid to change the belt for you then yes pay another 30 quid to get a new water pump. If its you doing it then check it runs smoothly and doesnt leak and put it all back together. The worst that will happen is that it starts leaking some time in the future and you have to change the pump. You'll be an expert at removing the belts from the first time
if I had a car that war in good nick and owed me 240 quid or whatever it is, then id explore every avenue possible that didn't cost anything.
of its a valve, and the seat is ok, how much will that cost? tenner for the valve?
Ps. Its easy to give advice when I know it won't be me grazing my knuckles and swearing at the thing. :-P
I hope you find what's wrong. I really do. You should go on a tour of the country in celebration if you get to the bottom if it.
Edited by jime17, 04 October 2014 - 12:47 AM.
#280
Posted 04 October 2014 - 04:12 AM
#281
Posted 17 October 2014 - 07:46 PM
Any progress? I was getting excited!
#282
Posted 17 October 2014 - 09:11 PM
Yeh I popped over, tinkered for 20 seconds and got it running perfect.
I'm just that kind of guy.
#283
Posted 18 October 2014 - 10:37 AM
Yeah, thanks for that Ross!
It broke down again just after you left though.....
#284
Posted 18 October 2014 - 12:18 PM
definately a squirrel in the sump then
#285
Posted 18 October 2014 - 11:53 PM
Called it!
