Renault Megane Scenic 1.9Dci Engine Swap
520 replies to this topic
#226 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 01 October 2014 - 09:27 PM
It might give me motivation to fix my daily haha.
#227 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 01 October 2014 - 09:48 PM
Ben, there's so many people watching this now, failure isn't really acceptable.
No pressure! (Except fuel pressure  :bah: )
#228 Carlos W
Carlos W
  • 10,114 posts
Posted 01 October 2014 - 09:51 PM
I've discussed a trip over to fix it myself.
The only issue is, if it's not an electrical problem it's a compression issue and unless the head is coming off this story ends
#229 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 October 2014 - 10:09 PM
I don't mind the head coming off but i can't really spend much more money on it unless it's going to guarantee a fix..
Ben
#230 Carlos W
Carlos W
  • 10,114 posts
Posted 01 October 2014 - 10:13 PM
Ben
Lets see what your tests prove
#231 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,139 posts
  • Name: Sean
Posted 01 October 2014 - 10:17 PM
Failure is always an option!!!
I genuinely hope this works out for you, but don't be afraid to cut your losses and run!!
#232 Carlos W
Carlos W
  • 10,114 posts
Posted 01 October 2014 - 10:34 PM
Whilst it's only time you're investing it's worth investigating the injector thing.
You're doing well being methodical and logical
#233 markyB
markyB
  • 93 posts
  • Local Club: Bomber County Minis
Posted 01 October 2014 - 10:36 PM
I too think you are close to the fault.
I had a Scenic once and they are a good car when working !  But I would have happily killed it with fire !!
Hope you get it sorted
#234 sledgehammer
sledgehammer
  • 3,098 posts
Posted 01 October 2014 - 11:08 PM
I would love it to be electrical / quick fix
but it don't explain the inlet noise / chugging
I think it's losing compression - if only there was an easy way to test compression
disconnect all injectors (wiring) , turn it over on starter , can you hear compression on all cylinders
or a raise in speed on one cyl ?
or can you hear air escaping from one of the cylinders ?
hope I'm wrong - cause you've had crap luck lately , & need a break
Edited by sledgehammer, 01 October 2014 - 11:11 PM.
#235 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2014 - 01:31 AM
I suspect it is chugging because it is only running on 3 cylinders.
Ill try these things you have listed if i get chance to work on it tomorrow.
Ben
#236 Carlos W
Carlos W
  • 10,114 posts
Posted 02 October 2014 - 05:43 AM
If it's not the injector wiring you could whip the head off and make sure all the valves are seating correctly. If they are, I think it's probably time to strip it for parts and get your money back.
#237 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 02 October 2014 - 06:15 AM
This is bugging me too.......... Diesles are not as over complicated ( to a degree ) as petrol engines. Im not up to speed that much on newer oil burners but did use to work on comercials and perkins diesels a long time ago. With regards to the chugging, I really do not know what to suggest  until you can get all 4 injectors working. If you know that the inector is working ( as you have swapped it into a working cyl ) then the only reason why it isnt firing HAS to be electrical IMO.......
Hopefully if you can get the injector firing, it may help to see why the vehicel is chugging/chuffing. Hell, it may even run smooth !!!
Keep us posted.
#238 Badboytunes
Badboytunes
  • 1,615 posts
Is fuel getting to the injector?
#239 Carlos W
Carlos W
  • 10,114 posts
Posted 02 October 2014 - 09:22 AM
It's getting to the union, and returning through the return pipe
#240 freaker
freaker
  • 1,378 posts
  • Local Club: mini fun club belguim
Posted 02 October 2014 - 02:20 PM
as said above,
get the injector working, would need to be electrical as its not wet.
not able to get a new injector loom for it cheap?
freaker
