I am going to fashion my own noid light using a side repeater loom and a 12v led sidelight bulb.
Renault Megane Scenic 1.9Dci Engine Swap
#211
Posted 01 October 2014 - 06:28 PM
#212
Posted 01 October 2014 - 06:50 PM
Yes do it,
generally petrol injectors are around 14 Ohms resistance, so they draw 1A or 14Watts at max flow... so with a side light bulb you will be safe and not damage anything,
just a thought... does the pipe to the injector need to be bled? I'm noit up on deisils but worth looking into.
#213
Posted 01 October 2014 - 06:52 PM
I think there needs to be some wire chasing back to the ECU.
You can make up a simple test circuit using the LED bulb.
Remember the LED only works one way
#214
Posted 01 October 2014 - 07:01 PM
ill bare that in mind
#215
Posted 01 October 2014 - 07:04 PM
this is getting exciting for some reason
#216
Posted 01 October 2014 - 07:05 PM
I agree mate, if there's no power to the injector, but there is to others it needs chased back to the ECU
#217
Posted 01 October 2014 - 07:19 PM
Are the pairs of wires the same colour to each injector?
#218
Posted 01 October 2014 - 07:22 PM
yes, beige and black i think
#219
Posted 01 October 2014 - 07:32 PM
Is there a fuel return on each injector?
#220
Posted 01 October 2014 - 08:01 PM
Yes, black plastic tubes that link the top of each injector to each other and back to the pump
#221
Posted 01 October 2014 - 08:35 PM
Yes, black plastic tubes that link the top of each injector to each other and back to the pumpIs there a fuel return on each injector?
Does fuel return from the cylinder that doesn't fire?
#222
Posted 01 October 2014 - 08:38 PM
yes
#223
Posted 01 October 2014 - 08:54 PM
#224
Posted 01 October 2014 - 09:17 PM
+1this is getting exciting for some reason
#225
Posted 01 October 2014 - 09:26 PM
well ill try not to disappoint!
