Renault Megane Scenic 1.9Dci Engine Swap
520 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 August 2014 - 05:50 PM
Hi all, I have the chance to buy a 2002 scenic for peanuts. Has long long mot and tax etc AC leather and all the whistles and bells. Very clean also
The owner says it has a misfire and it is probably an injector.
Any advice?
Ben
Edited by Ben_O, 26 February 2015 - 08:41 PM.
#2 Spiffingly Good
Spiffingly Good
  • 441 posts
Posted 28 August 2014 - 06:01 PM
If it's the same 1.9 dci engine as found in lagunas and traffic/vivaro/primastar vans they are prone to many problems. Firstly if fitted with the 6 speed pk6 gearbox expect to replace it.
They also have trouble with turbo failure, injector pumps and injectors.
Oh dear had a 03 Laguna 1.9dci and had to replace the gearbox before the turbo failed.
I now have a nissan primastar 2.0dci with the same gearbox and this has just failed at 50k motorway miles
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 August 2014 - 06:04 PM
so not a wise choice then?
#4 firstforward
firstforward
  • 824 posts
Posted 28 August 2014 - 07:14 PM
What engine does this have? OOPS OK I see it
Edited by firstforward, 28 August 2014 - 07:15 PM.
#5 firstforward
firstforward
  • 824 posts
Posted 28 August 2014 - 07:17 PM
If it is only an injector that is not the end of the world? Get somebody who knows to check it out, could be a lot of money to fix.
#6 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 August 2014 - 07:18 PM
Just spoke to the chap and he said it misfires most of the time but slightly.
He also said that it happened before and he had 1 injector replaced and it sorted it. Now the problem is back and he says the symptoms are the same so will probably be one of the other injectors now.
I don't know what to do, its so clean and has almost a years MOT and although not strictly my cup of tea, will suit my needs perfectly
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 August 2014 - 07:23 PM
5060019_b_e5846b18289eb1d5_zps119b1c6b.j
5060019_b_8863aad5079c7c7a_zps5bcbb1f9.j
#8 sledgehammer
sledgehammer
  • 3,098 posts
Posted 28 August 2014 - 07:36 PM
If your buying it for peanuts - then you won't lose much
run it till it dies - I would change the fuel filter first before trying to diagnose any faults
Renaults esp diesels have a reputation for electrical engine faults
but so do a lot of other makes esp Vauxhall (used to be good)
hope it's a good one - about time you had a bit of good luck
#9 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 28 August 2014 - 08:26 PM
How much is peanuts.......?
#10 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 August 2014 - 08:31 PM
Thanks sledgehammer.
Ill pop ver and have a chat with the bloke when i get back to IOW on tuesday
#11 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
The grand sum of.........wait for it..........
£175
Mot till july 15 and tax till november.
Yikes!
#12 Badboytunes
Badboytunes
  • 1,615 posts
Posted 28 August 2014 - 08:33 PM
It could be an injector, it could also be the fuel pressure regulator valve on the high pressure diesel pump. Might even be as simple as a dirty fuel filter. These engines do run better using genuine Renault filters. Electrics are also a know problem with these cars. Especially if it has the electronically controlled heating control panel
Also the EGR valve could be knackered/dirty too.
#13 Badboytunes
Badboytunes
  • 1,615 posts
Posted 28 August 2014 - 08:35 PM
£175
Yikes!
Buy it.......
You could break it and weigh in the scrap and make more......
#14 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 August 2014 - 08:36 PM
well i'm defiantly going to view it and price up all the bits and see how it goes.
It really is immaculate so if it's an easy fix then it will make an excellent car/workhorse
#15 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 August 2014 - 08:38 PM
Sod it, ill get it.
What's the worst that could happen
