Mini City, Mayfair And Sprite?
20 replies to this topic
#16 some1158
some1158
  • 369 posts
Posted 29 August 2014 - 08:54 AM
Thank you for the info! But does anyone know which model descended from the Mini 1000
'Mini 1000' was the way that any model with a 998cc engine would have been badged in the 70s (as different from a Mini 850, with the 848cc engine).  Both 850 and 1000 models were available with a range of trim levels, although the original City was only available as an 850. (See https://www.somerfor...ge=page&id=123, which shows you that in the late 70s you could have an 850 (standard) or 850 Super deluxe, or 850 City, and a 1000 (standard) or 1000 Super. These were then rationalised into 1000 City and 1000 HL, with the HL later becoming the Mayfair )
So basically any 1980s 998cc Mini is descended from the 1000 in terms of its engine. In terms of the interior trim, City succeeded the basic trim level while HL/Mayfair replaced the Super (deluxe) trim level. But both were upgraded through the run - e.g. from the mid 80s the City dashboard was revised with 2 clocks in front of the driver rather than the single central clock of the earlier model, and there were changes to wheel size, amount of chrome, etc., too.
#17 Ethel
  • 25,919 posts
Posted 29 August 2014 - 09:17 AM
I didn't know there was 850 City. The E had a 2.95 diff and the same high compression engine as the HLE Metro.
The Mayfair is Clubman spec roundnose, so if you equate the City to the 850 as the base model, I suppose there was no direct 998 saloon replacement, or the Mayfair is a hybrid of both.
I remember a Marketing Campaign playing on the Sprite and E (type) names as some sort of revival of old marques.
#18 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 29 August 2014 - 09:54 AM
Was it a 2.95 or a 2.76 in the City E? Or am I confusing it with the 2.76 from the MPI?
#19 Ethel
  • 25,919 posts
Posted 29 August 2014 - 10:51 AM
2.95 on 10" wheels 3.1 on 12's.
2.7 is also Auto.
#20 jjb60032
jjb60032
  • 43 posts
Posted 29 August 2014 - 05:12 PM
Cheers for replying  :proud:
#21 1984mini25
1984mini25
  • 8,784 posts
Posted 29 August 2014 - 05:46 PM
2.9 on the 998 city e and 25 with 12" wheels and on the sprite again with a 988 with the 10" mini specials.
Edited by 1984mini25, 29 August 2014 - 05:47 PM.
