Scuttle To Wing Gap
21 replies to this topic
#16 whistler
whistler
  • 1,898 posts
Posted 25 February 2017 - 10:00 AM
I've brazed the wing to scuttle gap up before for someone who wanted a smooth joint between the two. It's took a couple rods each side but did a lovely job of smoothing the seam. The big plus of brazing rather than welding was that if the wing ever needed replacing you could just melt the braze out of the joint.
One down side is the heat, although you can control it to avoid distorting anything it will take off paint within 2-3 inches. I found a paint gun with a long nozzle and a bit or wax oil inside the scuttle void  was required after wards.
The other downside of brazing is that it can crack over time.
#17 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 25 February 2017 - 09:09 PM
should be welded on the underside, and seam sealer just tidies the job
#18 CityEPete
CityEPete
  • 3,920 posts
Posted 25 February 2017 - 09:52 PM
Holy thread revival batman!
#19 tiger99
tiger99
  • 8,584 posts
Posted 27 February 2017 - 12:41 PM
They sometimes came out of the factory brazed, in the days when the press tools were in good condition and the joints fitted properly. The top of the A panel was also brazed to the scuttle.
Properly done, braze is ok, but protect it from electrolytic corrosion and don't let the MOT tester see it. Bronze weld, on the other hand, is also good, and stronger than braze, but the cost of a spool of MIG bronze is horrendous.
Last one I did was welded underneath and a spot of MIG between A panel and scuttle, as it had come out of the factory that way.
There are several satisfactory ways of doing it.
#20 WanaGo
WanaGo
  • 145 posts
  • Local Club: MOWOG
Posted 28 February 2025 - 01:46 AM
Thread revival number 2 ! lol
For those who seal the gap up between scuttle and wing, with a flexible sealant, do you do it after you paint so the sealant is visible and not body colour, or do you do it before paint and obviously use a paintable sealant?
I am unsure what way to go, as the sealant isnt body coloured and might look a bit weird, but if I paint over it and its flexible, the paint might crack or something while the sealant moves.
What is the correct answer here?
#21 StefanMini
StefanMini
  • 103 posts
  • Local Club: M.S.C.N
Posted 28 February 2025 - 11:58 AM
You need to put on the sealant first, and after that you paint it. You can put paint on almost every body sealant.
#22 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 28 February 2025 - 08:08 PM
From the factory they come with nothing in there, however after i weld the scuttle return to the wing return underneath and also add the little reinforcing bracket to the A panel to wing flange. I then flood the gap with primer and topcoat, then once that has hardened off i force sealant in as far as possible keeping a nice low finish in the gap then paint again. ( isal on the underside as well.)
My go to sealant is PS870B1/2 which is an Aviation sealant which copes with extreme temperature ranges and also has an anti corrosion mix in it as well. It's not cheap if you try to buy it. I use shelf lifed from work.
