Im due to collect my first classic mini this week, im not clued up on modified engines and it's fitted with the below setup
73.5mm 11cc DISH MEGA PISTONS
SW10 Duplex timing kit
Swiftune SW10 (286) Billet Camshaft
11 ARP head studs
HIF44 carb - rebuilt and reconditioned
Stage 4 cylinder head
K&N filter
Power flow oil pump
Rebuilt and reconditioned gearbox - no expense spared
Central oil pick up
New clutch (orange diaphragm) - clutch and flywheel balanced professionally
Facet solid state fuel pump
Custom loom from RapidFit looms and Megajolt Lite Jr ECU timing
It's currently setup with 5500rpm limit via the Megajolt.. Realistically what's a safe rpm limit for the above spec and for a road spec engine.. It runs nice how it is now but would be good to get it fine tuned and see what power it is
I think I'm going to get a pro set it up, I am based on the Norfolk/Suffolk border who do you reccomend?
Hope this makes sense
Chris
Edited by CPC, 25 August 2014 - 08:09 PM.
