So has any of you used the eaton m45 kit then? i would like to get a view of the two kits and what sort of problems and performance you have gotten from them.
thanks
Liam
Posted 30 August 2014 - 12:49 PM
thanks
Liam
Posted 30 August 2014 - 12:54 PM
Edited by HUBBA.HUBBA, 30 August 2014 - 12:55 PM.
Posted 30 August 2014 - 01:07 PM
i really like the look of the sc12 kit but there is very little information about them and even less about the results people have had. whats putting me off the sc12 kit is trying to get the charger....
Posted 30 August 2014 - 05:47 PM
Posted 30 August 2014 - 06:06 PM
Posted 30 August 2014 - 06:18 PM
Times it by 1.4I have been looking at sc12 supercharger kit.
I like it.
What bhp do you think I would get out of it on my engine?
my engine spec is Rob Walker 1293,stage 3 head, megajolt, turbo clutch, piper 270 cam.
At the moment it is 81bhp at the wheels.
Posted 30 August 2014 - 07:37 PM
I like it.
I make more ATW on my 1060 that you do with your 1293 however, on a suck through system the ceiling is about the 130-140 mark (At the fly). I say this as I haven't seen anyone publish higher figures...
No my 998 has been developed a little, in that I have a cam that works well and the inlet is well matched in terms of throttle body size, I run water injection, etc.
Overall simple stuff as there is a load of data on peoples spec and what works well, on the Ausmini forum or from Ben the builder of the kit. Sounds like you have a good base but I guess you might need to do some work to lower your CR and if you can't get it from the head new pistons will be an expensive upgrade, and it won't be a bolt on kit....
Posted 31 August 2014 - 01:24 AM
I spoke to Graham Russell, who grinds the cams for Calver, about the sc12 kit his response was..
" they just dont produce the power they should".....he also went onto talk about how he put one on the dyno, then got onto the maker and quized him about the lack of power, the maker said that his dyno must be out of whack..etc..etc..If Graham cant make one work, then there are not many who can. The sc12 will work, but it seems the pully size is the issue.
Also, he doesnt like the way the some kits run the belts over the harmonic balancer..
Posted 31 August 2014 - 06:30 AM
Edited by Gr4h4m, 31 August 2014 - 06:54 AM.
Posted 11 September 2014 - 01:07 PM
hi quick few questions
what cooling modifications have you had to make?.... im presuming there must be some
And would the sc12 kit work with a servo brake system? or would the servo be in the way of mounting the carb?
thanks
Liam
Posted 11 September 2014 - 03:13 PM
Posted 18 October 2014 - 10:45 AM
Posted 18 October 2014 - 11:00 AM
100 bhp and forced induction is easily achievable without too much of a high spec. decent head, cam and some forced induction 10 psi and you should hit 100 easily
I'm interested in your power figures here. I've had my supercharged mini on 2 different rolling roads and only 93bhp at the wheels was achieved, I've made everything correctly, smoothed and purges all the welded joints for better flow, boost is 10psi, but what are you doing to get 100bhp at the wheels? are you using a carb or fuel injections?? This isn't a dig, just interested......
Posted 18 October 2014 - 04:55 PM
92 on ausmini also makes a kit to use the sprintex supercharger which I am told is much better than the sc12.
Does anyone in the UK import these Sprintex kits? And is there any experience/information available about running these.
Posted 19 October 2014 - 06:55 AM
They use these superchargers. a 150 I think. http://www.sprintex..../superchargers/ then you need the kit from 92 on ausmini
