I have an SC12 kit. its a neat looking thing under the bonnet, IMO it looks a lot more 60's and has a very short inlet manifold, but I think to an extent they can all pool fuel a little its just the Eaton has a big slide for it to run down...
All of these statements are my opinion from running the charger. since about 2007. This is my fun car.
My kit has been reliable but then I have got it to a state of tune that suited me. I ditched the old worn out SU and used a bike carb.
I think Megajolt or mapped ignition is a must... you can do it on a dizzy but its not very ideal and imo dangerous on points.... as its too easy to go out of tune. plus most of them are worn out... and you don't want the timing scattering..
The guy that does the Sc12 kit, also makes a sprintex kit, but the chargers are generally only available new. so a bit more expensive but they are more efficient.
everyone will had issues at some point. The reliability is done the the following items:
- Your Compression ratio being correct
- the health of your current engine sticking more power on an old smoker won't help
- Ignition timing
- Fuelling
- How you drive the car, drive it like you stole it all of the time something will break, but then it will anyway.
The power on these kits is generally about 40%-60% more than you have now. A lot with all tuning it about how good the head is and then a suitable wide LCA cam, but they will work with a std cam.
Any questions on the SC12 I can try and help. I guess getting the charger is getting much harder, try AUS or the US. The kit is was very cheap compared to the eaton but I haven't checked the price or the exchange rate for a while...
