Allspeed Cg13 Build
53 replies to this topic
#16 StewartB
StewartB
  • 93 posts
Posted 29 November 2014 - 09:15 PM
cheers for the info the biggest problem I have is finding a 1.3 micra in northern Ireland might have to try some scrappys
definitely the way to go if you can get one at the right price, cheap, reliable, and with few mods can be reasonably quick(oh and not to mention 5 gears!)
Anyway slight update, starting to get this engine together now, few coats of paint on and it looks as good as new!
Still have some bits to go over, but overall think its looking good!
#17 l_jonez
l_jonez
  • 1,453 posts
Posted 30 November 2014 - 10:39 AM
Good choice in colour choice and smooth can cover....
#18 StewartB
StewartB
  • 93 posts
Posted 19 December 2014 - 11:40 PM
In the process of sorting inlet/exhaust planing to use the fire extinguisher as an inlet plenum, and using a k series exhaust which ill adapt to fit
#19 slack
slack
  • 65 posts
Posted 05 January 2015 - 01:22 PM
I have a question. This subframe is the CG13 from allspeed?
With this CG13 Subframe, we can fit the 1.3l micra engine without change the gearbox or we need to change for a later gearbox?
Thank you
#20 Artstu
Artstu
  • 830 posts
Posted 05 January 2015 - 01:34 PM
Thank you
Correct. Although the rear mount needs modding to allow the gearchange support to be fixed, and you need to source driveshafts too. Perhaps Rob (Allspeed) is working on this?
http://www.allspeede...subframe-detail
#21 slack
slack
  • 65 posts
Posted 05 January 2015 - 01:57 PM
Thank you
Thank you.
I sent a email to rob about the driveshafts and about the CG13 gearbox and he reply me this:
"Hello,
The CG13 subframe will accept the 1.3l engine but only with the cg13 later gearbox.
We do not currently offer driveshafts for the Nissan conversions.
Regards "
So for the current cg13 gearbox we need to modding the gearchange support althought we need to change the gearbox for the later one correct?
Thank you
Edited by slack, 05 January 2015 - 01:57 PM.
#22 Artstu
Artstu
  • 830 posts
Posted 05 January 2015 - 03:46 PM
Thank you
All 1.3 and later 1.4 Micra's have the same sized larger gearbox. Only the early 1.0 cars had the smaller gearbox. I saw the gearchange issue mentioned in another build thread, I think it's the other thread you asked this question in.
Edited by Artstu, 05 January 2015 - 03:47 PM.
#23 slack
slack
  • 65 posts
Posted 05 January 2015 - 05:34 PM
Thank you
Nice. Thank you
Edited by slack, 05 January 2015 - 05:46 PM.
#24 smudger068
smudger068
  • 344 posts
Posted 06 January 2015 - 06:49 PM
I have just seen this. And was about to purchase a frame but to what extent does the frame need modifying?
Lee
#25 StewartB
StewartB
  • 93 posts
Posted 06 January 2015 - 10:03 PM
Thank you
Im unsure about box differences beetween early 1.3 but im using a 1999 box and its bolt in
Lee
assuming artstu is talking about the issue i hit with mock up the gear change rod is bulky where it bolts to the gearbox, it fits on in neutral position but depending on what gear is selecting(1,3,5 i think) it hits off the bottom of the frame to combat this ill be cutting the corner of the rod mounting a few mm the frame doesn't need modified. ill try to get a photo of what i mean at the weekend
also for driveshaft a machine shop should be able to make them up for you (butting/sleeving the cut micra and mini shafts)
Edited by StewartB, 06 January 2015 - 10:04 PM.
#26 StewartB
StewartB
  • 93 posts
Posted 06 January 2015 - 10:10 PM
got exhaust manifold sorted out Albeit the welds look Sh*t. I'll likely look into getting something custom done once its up and running
#27 Artstu
Artstu
  • 830 posts
Posted 07 January 2015 - 11:34 AM
Thank you
Lee
I read about the issue in Al's build thread. What have you done with the gearchange support rod then? Without actually seeing the issue I'm second guessing, perhaps part of the original rear mount can be added, the bit that the support bar bolts to.
Attached File  PICT0115.JPG   114.57K   31 downloads
#28 StewartB
StewartB
  • 93 posts
Posted 07 January 2015 - 08:28 PM
Thank you
Lee
christ now im wondering! ill need to get it up on the lift this weekend and have another look may have been an over sight on my part!
#29 StewartB
StewartB
  • 93 posts
Posted 10 January 2015 - 01:39 PM
so i got to shortening the gear linkage today as it was brought up about the support bar
for those asking about problems with it the frame i got for th 1.3 had an extra bolt hole on the rear engine mounting
so you can still use the support bar, you can see here where with the car in 5th gear it just rubs the frame and no more so ill just buff a small bit off and it will be fine
RL]
after shortening the rods i had a change of plans and have cut the support rod off again and im going to rubber mount the gear shifter to the floor and see how it goes there should be enough flex in the mounts im planning to use that there shouldn't be any issues doing it this way (also the mounts on the frame are pretty substantial)
Edited by StewartB, 10 January 2015 - 01:40 PM.
#30 smudger068
smudger068
  • 344 posts
Posted 10 January 2015 - 06:20 PM
Excellent Chap thank you
Also how long did you have to wait for your frame?
I will get mine ordered
