1275 cam
Posted 02 July 2004 - 05:12 PM
I've finally managed to acquire a 1275 for my mini, as the 1098 has buggered valve stems (must be acres of space between valve and stem). I've got the 1275 down to block and box, everything else is off, so i can fit new oil pump and timing chain. My mate suggested that while I have it this far apart (i'm splitting the box and block to fit a central oil pick-up too), why not fit a slightly racier cam to the lump. Must admit i'm tempted, but i need to know what would be the best cam for the job. Its going to be used for fast road use, maybe the occasional track day, but i need it to run fine at slow speeds in traffic etc. What would anyone recommend?
Tom
Posted 02 July 2004 - 05:37 PM
If your fitting a central oil pick-up, are you aware you have to take some of the gears out to fit it? Its easy enuf to do, just take the speedo drive housing off and with a long drift, knock the main shaft out that the row of gears are mounted on. It should come out easily onc eyou free it a bit, it will slid right out. With the old oil pick-up undone, lift the gear shaft and pickup out together. As Haynes says - re-fit is the oppostie to removal...
Good luck.
Posted 02 July 2004 - 06:07 PM
Posted 03 July 2004 - 06:26 AM
Posted 04 July 2004 - 04:17 PM
Sorry for all the questions!
Posted 04 July 2004 - 06:56 PM
Fitting depends on how quick you can do it, I can get the engine out, do all these things and back in in a day, but that is from experience too.
The cam and crank have a key in them and the pullies are sided, so they will only go on one way. What I do is put two marks on the cam pully, one at 10 o'clock and one at 2 o'clock and the same on the crank pully and in the corresponding place on the chain to all these.When you take the pullies and chain off, they should all come off together, but the marks are there if you do drop a pully by mistake.
Posted 04 July 2004 - 08:27 PM
Posted 04 July 2004 - 09:19 PM
Posted 04 July 2004 - 09:39 PM
Posted 04 July 2004 - 11:44 PM
Posted 05 July 2004 - 05:01 PM
Posted 05 July 2004 - 05:49 PM
Posted 05 July 2004 - 09:02 PM
JOKE! Please don't try it
Posted 05 July 2004 - 10:21 PM
Posted 06 July 2004 - 02:11 PM
