A length of White 1.0mm 32/0.20mm. would be a good gauge wire for a coil feed wire and will take 16.5a
You can work out how many amps a 12v coil draws by the formula
amp = volt / ohm
12v dev by 3.5ohms = 3.4amps approx
Posted 25 August 2014 - 09:26 PM
amp = volt / ohm
Posted 26 August 2014 - 11:14 AM
Posted 26 August 2014 - 11:47 AM
Volt drop thicker wire gives less and more voltage on starting
Posted 26 August 2014 - 06:55 PM
Posted 26 August 2014 - 08:51 PM
Yes mate correct.
Posted 26 August 2014 - 09:02 PM
Posted 26 August 2014 - 09:11 PM
Did you not say that you are running a 65D distributor with the factory electronic ignition?
If so, you need the electronic ignition coil which is not 3 Ohms. Dave will be back soon and I'm sure he knows the number for the coil you want.
Posted 26 August 2014 - 10:36 PM
@Doug I went to the first post and yes its there the OP is using a 65D4M distributor so the only coil you can use with that distributor with the module is a GCL !43, and yes you still need the new coil feed
Posted 27 August 2014 - 05:33 PM
Posted 29 August 2014 - 12:42 PM
Hi Olly hope your getting your head around this, I'm in the same situation at the moment regarding p/w wire and y/w wire and just reading through your thread to see if it helped, just wondering if you could post a few pics up of your setup.
Glen
Posted 29 August 2014 - 02:35 PM
Glen its all in the FAQs about the ballast and standard ignition here http://www.theminifo...d-12v-ignition/
Its straight forward enough mate
Posted 29 August 2014 - 04:09 PM
Yeah i have read a lot of your info on there bud and managed to get my head around a lot of it, i just like to see pics of things so i know I'm on the right road due to a lot of bits missing when i first started
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
