Engine Block Painting
Posted 14 August 2014 - 07:38 PM
Andy
Posted 14 August 2014 - 08:29 PM
Ee.g the halfrauds engine red high temp paint or whatever colour you want
The last engine I painted was mostly bare metal with some areas where the original red paint was still stuck tight like you described.
I degreased the individual parts then panel wiped them and brushed painted both engines bellow and they looked brilliant. The green engine was probably left of a week before is was ran so the paint had plenty of time to harden off.
Posted 14 August 2014 - 09:14 PM
My local paint supplier does a 'Fast Engine Paint' in whatever colour you need? It's somewhere between Chassis Paint and Polyurathane.
Posted 15 August 2014 - 12:53 PM
Andy
Posted 15 August 2014 - 02:53 PM
I used hammerite
Posted 15 August 2014 - 03:30 PM
Posted 15 August 2014 - 03:40 PM
I went to a local paint supplier and had some made up (pretty much any colour you want). Just make sure you ask for high temp. In terms of price it was on par with Halfords, but your getting proper bodyshop paint and should have wide spray nozzles. I had some beige etch primer and a lime green (can't remember the name atm). 1 can of each was enough for the block and head.
To clean my block I used a drill with wire brush, then sent it to a machine shop for a hot wash. Obviously if yours isn't in bits then that might be a bit tricky! lol
20140624_212058f.jpg 41.24K
36 downloads
Edited by frobnitzz, 15 August 2014 - 03:41 PM.
Posted 15 August 2014 - 03:57 PM
The engine doesn't really get hot enough to warrant a high temp paint. It's all down to the preparation and ensuring every bit of grease and oil is removed.
I've used Hammerite before with no problems, as I do on brake callipers.
For my engine build, I'm using Granville black engine paint. It's very well rated.
Posted 15 August 2014 - 08:15 PM
Thanks again fellas, actually picked up some red hammerite. The engine is all prepped and ready for painting. Will update the thread over the next few days.
Andy
Posted 16 August 2014 - 11:27 AM
Sperex engine enamel gets my vote. Mart.
Posted 16 August 2014 - 09:38 PM
Posted 30 August 2014 - 08:03 PM
Can you tell me which red paint you used please? looks nice and bright, great job too by the way :) I'm painting mine red and looking for a very bright red engine paint.
Posted 30 August 2014 - 08:23 PM
Use an etch primer first, and then anything you like.... I've even seen engines painted in Dulux.
