Air Filter Decision. Pros And Cons
30 replies to this topic
#16 Ethel
  • 25,919 posts
Posted 14 August 2014 - 11:21 AM
You won't have gained 9 ponies from putting your car on the rollers. Any power increase will be from something the dyno guy altered, usually a bit of needle profiling and tweaking the overall advance. BL/Rover will have put far more than dyno time into developing the factory tune. It's best to be sure you are atleast starting from the correct factory settings, otherwise your gains are likely to come from compensating for loosely related faults and will have yet more knock on effects. Say your timing chain has stretched, better to replace it and regain the correct valve timing than turn the dizzy with the sole intention of getting peak power in the artificial operating conditions you get on a stationary rolling road.
Rolling roads can be useful, even if the engine hasn't changed, the petrol it runs on isn't the leaded stuff that was in the pumps when small bore A's were developed. They aren't a fix all panacea, that's all.
#17 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 14 August 2014 - 03:05 PM
Well yeah he obviously tweaked things. I didnt just mean it gained 9hp from running it on the rollers.
Edited by Moggyton, 14 August 2014 - 03:06 PM.
#18 blacktulip
blacktulip
  • 6,224 posts
Posted 14 August 2014 - 05:14 PM
I say do as many free mods as you can then get down to a reputable rolling road. There are many ways to make it go faster for free.
#19 ShaunaFTW
ShaunaFTW
  • 594 posts
  • Local Club: TurboMinis
Posted 14 August 2014 - 05:19 PM
Maybe keep your existing set up and get it serviced and a tune up on a rolling road..... :0) it'll make a world of difference
Cheers james
Right, a few people have mentioned rolling roads to me now, I think I'll look into it, if I take it to a rolling road place im guessing they can improve the output for me there right? By doing whatever they think? I reckon I'll look into the costs of it.
Thanks.
Try http://www.hitechmot....uk/contact.htm :)
EDIT, found link!
Edited by ShaunaFTW, 14 August 2014 - 05:24 PM.
#20 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 August 2014 - 06:50 PM
im just debating if id be better off covering the holes, and piping with duct right up behind the grill, so its just the coldest air possible being pushed through the filter box.
These things don't really work. At least not in a Mini. They appear to work in other cars because more modern machines have quite effectively sealed engine bays, often with a very inadequately sized air intake provided. The induction kit actually works simply by providing a larger opening in many cases, not because it provides cooler charge. In a Mini the engine bay has a massive open front like a basking shark's mouth. This is also why it's apocryphal that your pancake is taking in hot air. Testing has shown that above 9 - 12 mph the temperature of the air at the bulkhead is the same as outside and it's at a considerably higher pressure. The intake would have to be really close to the exhaust manifold to pick up any heat. The old Cooper air cleaner has the intake in possibly the only really bad position and it's not like the car performed badly as a result. The real disaster with those kits is that they use corrugated hose. This stuff is terrible for flow, the ridges create massive turbulence inside and the turbulence limits flow. The hoses flow only as well as as a smooth hose of 2/3 to 3/4 the size of the corrugated one. To make this work for real you need a solid walled, smooth, massive cross section duct from the grille to the carb mouth which needs to be properly gas flowed and nicely tapered. Some Miglias run such things but they take up a lot of space and cost a lot of cash for little real gain.
#21 Mrstars11
Mrstars11
  • 192 posts
Posted 14 August 2014 - 08:23 PM
So in theory, am I right in thinking id be better to use the filter box with element filter in and leave the holes bored in it. Just don't bother with the ducting.
#22 Ethel
  • 25,919 posts
Posted 14 August 2014 - 09:11 PM
Yes,
I'm not sure if I owe Moggyton an apology, I didn't think that's what you meant even if I gave that impression. I was trying to emphasise that rolling roads are just diagnostic tools that can't produce the best results if you don't have the other stuff sorted beforehand. Unless something's been done that changes the fuelling and ignition requirements of the engine it's better to start elsewhere.
#23 Moggyton
Moggyton
  • 1,152 posts
Posted 14 August 2014 - 10:57 PM
Yes,
Of course you dont owe me an apology. And yes, he did quite a bit of needle profiling :P
#24 661
661
  • 212 posts
Posted 15 August 2014 - 08:53 PM
Is it true to say that if you have a k&n cone on a hs4 then the stub is worth fitting?
#25 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 15 August 2014 - 09:35 PM
This is what I've got, what's this stub you talk about?
#26 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 15 August 2014 - 09:48 PM
The stub stack goes inside the filter, it improves the flow into the carb body. In the Yellow Vizard book the flow through the carb increases by 5-6%, which is a big improvements for such a small thing...
http://www.minispare...N etc/SS51.aspx
#27 BronkoMini
BronkoMini
  • 1,484 posts
Posted 15 August 2014 - 11:01 PM
Ah ok thanks
#28 Mrstars11
Mrstars11
  • 192 posts
Posted 16 August 2014 - 09:35 AM
i currently have this set up with the stub, and im swapping it this weekend to the original filter box with k&n element filter, and 6 holes drilled into the box.
ill report back if i notice any difference.
#29 Ethel
  • 25,919 posts
Posted 16 August 2014 - 10:03 AM
Some filters have a stub stack built in. They're for the original style K&N's with sheet metal baseplates.
#30 coopdog
coopdog
  • 4,506 posts
Posted 16 August 2014 - 11:26 AM
I bet that you don't :L
Just noise difference
