Hi all!
Went to mot.. Only problem is a bad handbrake
So : how the hell do I adjust it? I thought I adjusted it ( at the hanbrake itself) but clearly it wasn't tight enough..
Any ways I can make it tighter?
Posted 08 August 2014 - 10:20 AM
Hi all!
Posted 08 August 2014 - 10:34 AM
Edited by Fossy313, 08 August 2014 - 10:34 AM.
Posted 08 August 2014 - 10:38 AM
U need to adjust the rear brake adjusters, and it may not be the handbrake itself jack it up and make sure the linkages underneath are not seized.... Other than that it's a new handbrake cable.
Probably the cable then I think, because when they tested the 'normal' brakes everyhting was fine...
Posted 08 August 2014 - 10:44 AM
Posted 08 August 2014 - 11:30 AM
Posted 08 August 2014 - 11:36 AM
I'll buy a new cable tonight...
And then adjust everything properly etc, so I get a good start..
The mini will be finaly on the road then after more than a year of work in it :)
The only other remark is that there is play in the balljoints ( although I fitted new ones) But they basically just need to be tightened up.. :)
Edited by Dusky, 08 August 2014 - 11:36 AM.
Posted 08 August 2014 - 12:12 PM
The handbrake should be adjusted at the drums - not at the lever.
Slacken the nuts at the lever off.
Adjust the brake shoes on the drums until the wheel will spin freely for about 1 full revolution
Now re-tighten the nuts at the lever to set the lever travel (approx 4-5 clicks for full handbrake engagement)
I always give some good tugs on the handbrake cable where it runs down the radius are whilst adjust the shoes, it helps centre them and also ensures everything is free.
Posted 08 August 2014 - 02:53 PM
dusky if the balljoints need re shimming re shim then, but only if they are new, at the price of balljoints as well just replace them and get a shim pack too, unless they are new then take them off and shim them now.
Posted 08 August 2014 - 03:17 PM
They are almost new ( drove like 30 miles with them maybe?)
But mot tester said it were the nuts that aren't tight enough... Don't think I shimed them wrong
Posted 08 August 2014 - 07:22 PM
It will not be loose ball-joint nuts. The threads are taper locked and the nuts just pull the taper in fully. If the taper was not in tightly because the nuts were loose it would be very obvious with very slack suspension. If there is play it will be shimming not correct or new ball joints needed.
It would seem that the tester knows nothing about Mini suspension.
Posted 08 August 2014 - 10:20 PM
Posted 08 August 2014 - 10:31 PM
