stage 1 minispares is good enough.. uprated needle and carb springs, alloy inlet manifold and lcb exhaust manifolds, and high air flow air filter.. all of this will give your standard mini a significant torque increase which in turns gives your mini more umphhh.. you will feel the difference..
I did this in the summer when my exhaust snapped on a cold summer morning, went with the cooper freeflow instead. definitely a good investment, yet to set up the needle yet and will do this next summer.
and you should consider the 5 pound TMF+ account.. the 7.5% discount on minispares parts are great :) they also have so many more discounts on other sites..
did this a while ago as you can see from my tmf+ membership. it paid itself back in just the stage one purchase and i saved 35 quid on top of that with the parts i bought.
Can I just hi-jack this thread....?
Going to fit a Stage 1 to my 998. The previous owner for some reason, fitted an RC40 back box. the rest is completely std.
He's fashioned a lovely connector between the small & large gauge pipes - begs the question why for the little extra, he didn't go the whole hog.?
Anyway, I diverse.
With the back box RC40 in place, I can buy the seperate parts to make up the Stage 1 kit.
My question is; Is this a DIY job.? I have just completely my first head gasket replacement thanks to the Haynes Manual. I'm far from a mechanic but am 'handy'.
I'm worried that the carb. part of the equation is a delicate one - ideally I'd like to strip down the carb. and refurbish (as it's off). I've seen the exploded diagram in the Haynes manual, I can just see me with a hundred small pieces all over the floor!!
Happy to replace exhaust & manifold, having done so for the HG. It's the Carb. needle that's worrying.
And I'd definately have it set-up on a dyno immediately after. Should I leave the carb bit to them, and would driving with std. needle for a week or two be 'harmful' to the engine..?
Sorry for hijacking, but better than starting a new topic.
cheers as always
the rc40 is said to be the best exhaust for minis, i went with maniflow for the sake of the fact its something that is high quality and will last the test of time and also to support local to me british engineering. the freeflow is a piece of artwork in itself tbf lol.
the exhuast fitting is definitely a diy job, it will take time and stress you out as it seems like a bit of a rubix cube in ways to solve it. i paid a man (retired mechanic and family friend) a small amount of money and he very kindly fitted it for me whilst i was at work.
not setting up the needle isn't harmful as such, it just means that your mini wont be running as efficiently as it could be. although be careful about where you take it to tune as my local dyno and tuning centre wasn't recommended by my local mini club.
to summarise, do your research and ask people in the know for their opinions, they may even get you a discount directly with the company. a stage one kit is your first big investment to better things so go for quality parts that will take the test of time. there is plenty of good content and threads on here to take advantage of which will give you a strong start on where to start. tmf+ is also recommended ;)
Edited by Auscar, 19 December 2014 - 10:39 PM.
