iv gone and got brake fluid on my seats how can i clean it up??
Spilled Brake Fluid :/
Posted 05 August 2014 - 10:01 AM
Posted 05 August 2014 - 10:56 AM
Posted 05 August 2014 - 10:59 AM
cool thank you. i guess wait for the water to dry before i hoover so i dont get electrocuted or do i need one of those carpet cleaning hoovers?
Posted 05 August 2014 - 11:13 AM
Best to hire a carpet hoover, what id do is to try and wipe most of the brake fluid up asap
Posted 05 August 2014 - 11:17 AM
yeah i wiped it up, was a tiny spill, and tried upoulstry cleaner but then its still there. thanks for your help, think my nan has a carpet hoover so will ask her now
Posted 05 August 2014 - 11:22 AM
If the seats are leather you may be able to use a small amount of petrol followed by some soapy water then immediately wiped dry
Edited by cal844, 05 August 2014 - 11:22 AM.
Posted 05 August 2014 - 11:25 AM
cloth
Posted 05 August 2014 - 11:48 AM
Use the soapy water and carpet hoover then :)
Id leave the car in the sun with the windows closed after youve finished hoovering to allow any remaining moisture out
Posted 05 August 2014 - 11:58 AM
For DOT-3 and DOT-4 fluids, stick with water based cleaners. Those brake fluids can mix with water. If you are running DOT-5, consider using a more aggressive chemical cleaner (I would start with spray brake cleaner) to blot the fluid out. Regardless of fluid type, apply the cleaner using a very wet cloth and blot, then use a dry cloth to blot the fluid and cleaner away. It may take several attempts to get it out of the seat if the brake fluid has had time to soak in.
Posted 05 August 2014 - 12:01 PM
im just about to go and get the seat from the garage and give it a go. thank you for the advise guys, i'll try it all and let you know how it goes
Posted 07 August 2014 - 05:45 PM
Posted 07 August 2014 - 06:12 PM
