OK just for fun which head gasket would you go for ? The engine is a 1400cc tuned A series (not A+). compression ratio of 10.5:1, center main strap (you get the picture).
A : 3 shim from MED
B: a good quality copper one
Posted 02 August 2014 - 07:17 AM
A : 3 shim from MED
Posted 02 August 2014 - 07:24 AM
Posted 02 August 2014 - 08:57 AM
Not out of the question, if it's the right one
Mini Technical Sections →
Problems, Questions and Technical →
Can You Help Me Guys With My Hs4Started by Notwabel , Yesterday, 11:32 PM engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
Full Rebuild MethodologyStarted by PeteD , 16 Nov 2024 engine, electrical |
