Allspeed Cg13De Micra Build
165 replies to this topic
#121 al_reidy
al_reidy
  • 351 posts
  • Local Club: Geeks N Freaks
Posted 05 May 2015 - 02:17 AM
Yeah true, let's hope it doesn't happen!
#122 al_reidy
al_reidy
  • 351 posts
Posted 10 May 2015 - 11:42 AM
my two mini's - turbo conversion getting there. welding done, bar the exhaust downpipe. speaking of which i think I'm going to try and cram another silencer under the car. a small jetex one :
http://www.jetex.co....ss&dia=2.0 inch
Round silencer box [MIDI] [2 inch] [stainless steel] - Dia=100mm / L=417mm u415100r.jpg
#123 miniobsessed
miniobsessed
  • 211 posts
Posted 12 May 2015 - 04:36 PM
But remember the turbo will muffle the exhaust note compared to what it was and any unnecessary back pressure will slow your spool-up time and reduce maximum boost.
#124 al_reidy
al_reidy
  • 351 posts
Posted 12 May 2015 - 05:07 PM
true, i just don't want to look / sound like a chav.  :D
#125 miniobsessed
miniobsessed
  • 211 posts
Posted 13 May 2015 - 12:04 AM
With 200+ bhp per tonne they won't be looking at you for very long :-)
#126 al_reidy
al_reidy
  • 351 posts
Posted 02 June 2015 - 02:50 PM
Small updates really -
Injectors are installed from a 1.6 almera , you simply leave the rail alone and replace the injectors in the rail.
i really hope they are enough to power the turbo with standard engine internals. if not i can over pressure the fuel system now as i have changed the fuel rail to a non standard FSE pressure regulator.
RS turbo inlet charge cooler fitted ... kinda .... to the front.
Compressed air feed from the turbo routed under the car to the charge cooler, from that to the intake air temp sensor (new webcon item)
Air filter attached and made to fit in the only space available now right next to the sump. this might get a bit saturated in wet weather so i might have to think again about this....
New Throttle body now remounted on the plenum.
Dump valve from a saab installed (i hope it doesn't go chhhhhh when i change gear like a proper chav)
I have also started to look at the loom situation - i have a simple but well made loom for the MBE ecu i have now (the DTA one was returned when they went bust)
Im going to have to rewire quite a bit, the injectors for instance don't use standard plugs. but the loom uses standard junior mini timer things. gah...
Next is a picture of the Allspeed drives shafts i have upgraded to, it looks like they were designed to use 2x the 3 prong cir clip style pot joints so i will be cutting out the channel about an extra 2 mm so that the spring clip can spring into it. at the moment the clip can't contact into the gap so you cannot drive it into the near side pot joint.
another lathe job i guess.
#127 lawrence
lawrence
  • 1,340 posts
Posted 02 June 2015 - 04:52 PM
Have you thought about an aux fan yet?
Mines only the 998 but has an alloy rad but she wil start to overheat in traffic
It looks fairly tight around your rad area with your top hose and the intercooler may impeed air flow somewhat
#128 al_reidy
al_reidy
  • 351 posts
Posted 02 June 2015 - 05:58 PM
yeah the rad fan, well the trigger will be a custom output from the ECU so that i can control it properly.
As for the fan itself in the past when it was the 1380 a-series i had it in the wheel arch pulling the air through the rad, i should be doing that again unless the space has changed.
i am completely winging it at the moment so it might change by the time i post again.
#129 666junky
666junky
  • 1,225 posts
Posted 02 June 2015 - 06:04 PM
This is insane and i love it :D
#130 al_reidy
al_reidy
  • 351 posts
Posted 02 June 2015 - 06:05 PM
BOOOOOOOST! hehehe
#131 al_reidy
al_reidy
  • 351 posts
Posted 14 June 2015 - 08:22 PM
Exhaust made
#132 al_reidy
al_reidy
  • 351 posts
Posted 21 June 2015 - 05:35 PM
it passed its MOT yesterday for the first time with the micra engine in it. No boost deliberately as its really out of tune.
pleased with it though, will get more info from the rolling road in a few weeks. happy days.
#133 lawrence
lawrence
  • 1,340 posts
Posted 21 June 2015 - 08:01 PM
Nice one :) how does she drive? And how is the fan system for cooling her working? I'm thinking of changing mine to pulling not pushing air when I change my engine over
#134 al_reidy
al_reidy
  • 351 posts
Posted 21 June 2015 - 08:42 PM
With the new ecu I set the fan to turn on with 85 deg and turn off at 80. It always manages to do that so far. No boost yet though. I'm still pushing the air through the rad for simplicity.
In terms of driving it's just the same at the moment other than massively out of tune. Still loads of torque as it did have.
#135 jamier-2007
jamier-2007
    Just On Tickover
  • 5 posts
  • Local Club: South East Minis
Posted 22 June 2015 - 11:52 AM
Is the wideband ok being so close to the turbo outlet?
