Allspeed Cg13De Micra Build
165 replies to this topic
#106 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 16 January 2015 - 11:01 PM
Brakes don't stop horsepower (unless you have your foot on the accelerator whilst braking :huh: ) they stop weight from a speed.
So given that more power doesn't need more powerful brakes unless the vehicle weight has changed or the it's got larger wheels (the wheel/tyre has more leverage on the disk/drum to overcome) A micra conversion should be about the same weight or lighter.
Where I figure a change does come in and where it may be logical to upgrade brakes is a more powerful engine may get the car up to speed quicker and therefore brakes need to stop the car more often this doesn't require more power but might require dissipating heat more quickly so upgrading to vented brakes or minifins on the back may makes sense?
That said I've read one of Keith Calver's articles saying half the time 7.5" brakes aren't getting hot enough to work effectively so perhaps there's enough ability to get rid of heat there already...
Getting 7.5" disks passed by the engineer (in Aust conversions need engineering approval) was the easiest part of the process all he asked was has the weight changed?
#107 al_reidy
al_reidy
  • 351 posts
  • Local Club: Geeks N Freaks
Posted 17 January 2015 - 07:35 AM
Interesting points raised, my personal reason for the big brakes comment was that currently with dot 5.1 fluid and 7.9" disks I get brake fade in back roads. I did get the same results with 7.5 setup and my 1380.
Equally the other reason for making the comment was that to get the initial bite feel for using as a daily car with the turbo would be better with a greater efficiency vs pedal travel / effort.
I was not expecting this conversation but it's been very interesting sat back watching you both debate :-)
I feel strongly that on a track day it will be brake fade and disastrous in its current state.
As they are non vented at the moment , cooling the brakes with ducting might help. but with the more metal of larger vented disks this limit will be much later and allow my horrendous driving to last a few extra laps.
I did run on my 1380 metro turbo setup at one point which when warm were amazing on track, literally pushing as hard as I could on the pedal would not lock the wheels, the braking force was epic. Pulling up on the steering wheel to aid forcing the pedal to the floor was needed.
I basically want that with 10" rims hence stating that a servo might help.
#108 al_reidy
al_reidy
  • 351 posts
Posted 04 February 2015 - 08:25 PM
thinking about selling the micra mini to start the turbo project. nothing wrong with it, just i will end up re-buying and taking out perfectly serviceable parts etc.
hmmm what do you guys think?
#109 slack
slack
  • 65 posts
Posted 04 February 2015 - 11:16 PM
Sell the parts (subframe, engine, etc) our all the mini? Send me a message with the prices please.
#110 vx220
vx220
  • 419 posts
Posted 05 February 2015 - 07:40 AM
Stick an ad up, you can always change your mind
Pm me if you do?
#111 al_reidy
al_reidy
  • 351 posts
Posted 05 April 2015 - 12:56 PM
Turbo... first day mocking up.
It helps when you know someone with a 1.5 tonne lathe, Tig and Mig welder !
Attached File  IMG_2402.jpg   78.48K   29 downloads
Mocking up where the turbo should sit. its very very close to everything important.... ah.
Had so many doubts about this but f**k it. why not.
Started by effectually joining all exhaust ports together with stainless pipe in the shortest way possible.
lathe used to recess the pipes into the plate.
Attached File  IMG_2400.jpg   67.76K   44 downloads
Attached File  IMG_2398.jpg   70.24K   34 downloads
Attached File  IMG_2401.jpg   57.89K   22 downloads
This next shot show where the turbo will hang... we hope.
Attached File  IMG_2405.jpg   59.89K   37 downloads
The charged air  and air intake need further thought though as the engine mount is in the way :-/
Attached File  IMG_2403.jpg   57.63K   33 downloads
Attached File  IMG_2404.jpg   67.7K   21 downloads
#112 al_reidy
al_reidy
  • 351 posts
Posted 05 April 2015 - 02:26 PM
Attached File  IMG_2389.jpeg   83.11K   26 downloads
Attached File  IMG_2392.jpeg   92.51K   15 downloads
Attached File  IMG_2391.jpeg   96.23K   21 downloads
Attached File  IMG_2393.jpeg   79.13K   11 downloads
Attached File  IMG_2394.jpeg   57.55K   16 downloads
Attached File  IMG_9264.jpg   58.63K   39 downloads
Attached File  IMG_9607.jpg   28.66K   25 downloads
#113 666junky
666junky
  • 1,225 posts
Posted 05 April 2015 - 05:08 PM
Nice one :D cant wait to see this in action. Ive been doing alot of work on mine recently and just want to say thank you for all the help youve given + all the useful pictures!
#114 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 06 April 2015 - 09:18 PM
Good choice on turbo! It works well on a 1275 A series so should be good on this too.
#115 al_reidy
al_reidy
  • 351 posts
Posted 11 April 2015 - 06:29 PM
some more welding done.
Attached File  IMG_2175.jpg   77.03K   13 downloadsAttached File  IMG_2176.jpg   58.05K   14 downloadsAttached File  IMG_7396.jpg   71.38K   21 downloads
#116 al_reidy
al_reidy
  • 351 posts
Posted 30 April 2015 - 03:41 PM
As I'm going for Dizzyless with the aftermarket ECU I'm having to source another way of picking up TDC.
My mate used the lathe to mount this bad boy ----
blanking off the Dizzy hole was also needed - more lathe work (will make bracket to stop the oil pressure firing it into the rad!)
it certainly makes the engine bay less cluttered.
more welding....
Oil return drilled and ting welded from the inside into the oil pan.
That was a ******* and a half to remove. you have to separate the gearbox slightly to get the pan off. ggggrrrr
Next my attention went to the throttle body. the stock one is full of crap i can't use really. or don't want to use.
A quick search found a stock MG alloy throttle body will do :-) bigger bore and flows better than the crappy nissan one.
In other news i have had to completely destroy a perfectly good front engine mount under the alternator as the input air side of the turbo was being a pain and not defying the laws of physics.
currently repositioning it by about 2 inch towards the pulleys etc.
#117 al_reidy
al_reidy
  • 351 posts
Posted 01 May 2015 - 05:32 PM
You can just see the new engine mount position under the alternator. the temp location on this also of the exhaust which will loop around and run under the engine in the normal place.
Need to figure out the wastegate actuator rod thingy. (its missing and upside down)
would like to run an intercooler but no idea where the bugger will fit.
might squeeze a very small one above the exhaust at an angle?
#118 lawrence
lawrence
  • 1,340 posts
Posted 01 May 2015 - 06:46 PM
In regards to the dizzy hole bung mate that's very similar to mine, I cut off the end of the origional and filled the hole with liquid metal, let me use the original rubber o ring too. There's not a lot of pressure behind it tho and I've had no movement issues from mine or leaks. Photo if it's handy at all
Lawrence
#119 al_reidy
al_reidy
  • 351 posts
Posted 04 May 2015 - 05:34 PM
i think the blow back from the boost pressure puts excess pressure in the head so it might pop out.
The spun blanking plug has a recessed channel and a O ring in it. its a tight fit but i think to be on the safe side a small anchor to a thread somewhere will be best.
#120 l_jonez
l_jonez
  • 1,453 posts
Posted 04 May 2015 - 09:30 PM
If your putting pressure into the crank case then you have bigger problems than a oil plug.
